Latest post Tue, Mar 5 2019 1:24 AM by ProjectEng01. 9 replies.
Page 1 of 1 (10 items)
  • Tue, Jan 24 2017 4:51 PM
    delayed write failure for file '_SearchDB_' errcode 0xc00000b5
    A friend of mine is having this issue. Randomly. He ran Path diag,  90MBs.
    All SM are green, no errors
    There are 2 SG, 1 64tb isis 5k and second one with 2 isis 32k.
    8 clients connected to dell 3024, and 2 to S25 as edge.
    this issue only happend in MC connected to S25, No all times.
    These 2 machines have Mojo DX capturing EX35, Z800 with Intel Pro 1000.
    Proyects are in Isis.
    I found this link http://community.avid.com/forums/t/135916.aspx
    best regards,
    best regards,
  • Tue, Jan 24 2017 5:18 PM In reply to
    • BobRusso
    • New Jersey
    • Posts 2,255
    • Points 27,835
      Moderator: Avid ISIS
      Moderator: Avid NEXIS PRO
    Re: delayed write failure for file '_SearchDB_' errcode 0xc00000b5
    What version of ISIS is being run? We fixed a bug related to this in 4.7.11.
    What version of Media Composer? Move the bin indexer out of the project to a local drive as a test.
    It sounds like there's an issue with the network.
  • Tue, Jan 24 2017 5:38 PM In reply to
    Hi Bob,
    Isis 4.7.7, MC 8.4.4
    What version of Media Composer? Move the bin indexer out of the project to a local drive as a test. WHERE is this? in MC?
    Regarding the network Issue, I dont know how to follow, because pathdiags worked fine...
    I ll try to change ethernet cables and maybe restart the S25 switch...
    best regards
    F!
  • Tue, Jan 24 2017 5:53 PM In reply to
    • BobRusso
    • New Jersey
    • Posts 2,255
    • Points 27,835
    I encourage you to upgrade everything to 4.7.11 as we have a fix that's related to this error.
    In the Find window, select Settings. The search data is saved to the project by default.
    Move that to a local drive.
  • Wed, Jan 25 2017 5:54 PM In reply to
  • Tue, Jan 31 2017 3:55 PM In reply to
    Hi Bob,
    heres the thing:
    This is a 24hour show, they cants stop.
    Can they try to install only Client 4.7.11 and leave Isis in 4.7.7?
    There are 2 swtiches there, 1 DelL N3024 whith 3 Isis connected and the 4th SPF+ goes to a Force10 S25.
    The issue are only in the Force 10 clients. They swapped clients between switches and the issue still in the Force 10...
    best regards
  • Tue, Jan 31 2017 4:12 PM In reply to
    • BobRusso
    • New Jersey
    • Posts 2,255
    • Points 27,835
    There is no difference in the effort to install the NEXIS client vs the ISIS. If the System Director is running 4.7.7, the NEXIS Client will be able to connect.
    The fix for this bug is in the System Director so the client alone likely won't fix it.
    Have you changed the location for the Media Composer Find database?
    It sounds like you've isolated it to the switch. Can the switch be replaced?
  • Tue, Jan 31 2017 9:30 PM In reply to
    SearchDB is the database for the Find function. Each repective "bay" folder has one for each project. You can try deleting this subfolder. MC will recreate it the next time the project is opened.
  • Wed, Feb 1 2017 2:09 PM In reply to
    Well, I re installed the config files for this edge sw and It worked fine!
    thanks Bob and Dom!
    best regards,
  • Tue, Mar 5 2019 1:24 AM In reply to
    • ProjectEng01
    • Joined on Wed, Apr 29 2015
    • Maryland
    • Posts 3
    • Points 25
    Hi Francisco,
    I’m running into a similar problem with the Juniper QFX5100 switches. What about your config file did you have to change in order to get rid of this write delay error?
    Filed under: , ,
