Latest post Thu, Nov 16 2017 2:26 AM by monica66. 9 replies.
Page 1 of 1 (10 items)
  • Mon, Jan 23 2017 9:10 PM
    • mojovideo
    • San Diego, Ca
    • Posts 61
    • Points 880
    Trouble importing Sony FS5 XAVC media in AMC
    Hi-
    I just bought a Sony FS5 4k camcorder.  I shot my first test footage and was unable to import the media in AMC. However, I was able to import the media into Adobe Premiere Pro (latest cloud  versio 2017).  Is AMC version 8.4.0 able to read XAVC codec?  I dont want to have to update AMC, since I will be forced to buy the monthly subscription.
    Brian
    My Computer:
    Mid 2010 Apple pro Tower
    OS 10.11 (El Capitan)
    48G ram
    2.8 GHZ processor
    Quadcore Intel Xeon Processor
    ATI Radeon HD 5770 1024 MB Graphics card
    Media Im trying to import:
    1920 X 1080/ 60i
    XAVC codec
    Shot on Sony FS5 4k camcorder
    Apple 2.8ghz quad-core Intel Xeon w/48GB Ram running Avid Media Composer Version 8.4 23 inch HP 2310M flat screen Monitors (2) Sony Trinitron 19"... [view my complete system specs]
  • Mon, Jan 23 2017 9:54 PM In reply to
    Re: Trouble importing Sony FS5 XAVC media in AMC
    You need the Sony AMA plugin.  Nabit has taken over development of that.
    http://avid.force.com/pkb/articles/en_US/Download/en394827
    http://www.nablet.com/ama-plugins/
  • Mon, Jan 23 2017 11:37 PM In reply to
    • mojovideo
    • San Diego, Ca
    • Posts 61
    • Points 880
    I downloaded the Sony AMA plugin.  Still unable to import or AMA link media.  Suggestions?
  • Mon, Jan 23 2017 11:50 PM In reply to
    Did you manually select that plugin in the SOURCE BROWER? "Automatic" won't do it.
  • Tue, Jan 24 2017 3:52 AM In reply to
    Which specific XAVC codec is it?
    XAVC-I and XAVC-L should work.  XAVC-S does not work.  Sony never bothered adding support for it in its plugin, and Nablet just took over development and has not yet added support for that format.
  • Wed, Jan 25 2017 12:47 AM In reply to
    • jdcoletv
    • Joined on Tue, Aug 16 2011
    • Posts 83
    • Points 995
    I use XAVC WITH THE FS5 routinely with no issues.  Just have to make sure to select the proper codec prior to trying to connect to it. The FS5 uses XAVC-L.
    MacBook Pro (15-inch, 2017) running with 16gb and Sierra (10.12.6), Radeon Pro 560 4096 MB. [view my complete system specs]
    Regards,
    Jeremy
  • Fri, Jan 27 2017 10:34 PM In reply to
    • mojovideo
    • San Diego, Ca
    • Posts 61
    • Points 880
    Thanks everyone-
    So I was able to AMA link media to my project bin in AMC.  However, can I import the media into my project bin so I can reformat my SD cards without the media going offline?  I have had no luck with this so far
    Brian
  • Fri, Jan 27 2017 10:39 PM In reply to
    You would want to CONSOLIDATE or TRANSCODE, not import.
    But I would have a copy of that media from the card, in it's original folder structure, as a backup. If something were to happen with the Avid media you'd have no way to rebuild the project.
  • Sat, Jan 28 2017 12:08 AM In reply to
    • jdcoletv
    • Posts 83
    • Points 995
    Kevin Klimek:
    With my FS5 footage, I make two copies of the footage, then AMA link to it during the rough edit. Prior to doing a finish edit I transcode the footage. Whatever system you develop, stick to it so it becomes second nature. You really don't want to edit using the media in the SD card. It will slow you down, as well as add risk to the edit.
    Regards,
    Jeremy
  • Thu, Nov 16 2017 2:26 AM In reply to
    • monica66
    • Joined on Mon, May 27 2013
    • Posts 7
    • Points 10
    Try to encode XAVC to DNxHD codec.
