Latest post Mon, Jan 30 2017 4:55 PM by mmagder. 6 replies.
Page 1 of 1 (7 items)
  • Thu, Jan 19 2017 8:03 PM
    • mmagder
    • Joined on Wed, Sep 1 2010
    • Passaic NJ
    • Posts 198
    • Points 2,515
    8.7.2, Can't drag the source record monitors to size of screen
    I can make them smaller only, they open part way then stop. Not able to open to full size of montior.
    never had this before.
    Mac OSX 10.14.1 3.8 GHz Intel Core i5 MC 20180.10 [view my complete system specs]
  • Fri, Jan 20 2017 2:49 PM In reply to
    • RalphC
    • Joined on Wed, Sep 2 2015
    • Posts 1,765
    • Points 19,455
    • Avid Customer Advocate
      Avid Customer Service
      Avid Employee
    Re: 8.7.2, Can't drag the source record monitors to size of screen
    Hello mmagder,
       I created a case for support to investigate 03129630.
    Regards,
    RalphC
  • Sun, Jan 22 2017 4:17 PM In reply to
    • mmagder
    • Passaic NJ
    • Posts 198
    • Points 2,515
    yes, thank you
  • Wed, Jan 25 2017 5:22 PM In reply to
    • mmagder
    • Passaic NJ
    • Posts 198
    • Points 2,515
    i spoke to avid, they said if you are using 2 monitors, and they have different aspect ratios, ie. one is 16:9 and the other is 4:3, they won't work together. This is what i have, i am editing on a 16:9 and this is the one that won't let me drag record/source monitors bigger. Which is strange because it worked in earlier versions, the timeline does drag full screen though. Avid said they changed it, this is now the way it is.
  • Fri, Jan 27 2017 9:59 AM In reply to
    • Hansa
    • Joined on Tue, Sep 5 2006
    • Edinburgh, Scotland
    • Posts 413
    • Points 5,160
    I was very concerned when I read your post as I have 6 systems on MC 8.6.5 that have 4:3 screens attached to 27" iMacs waiting to be upgraded to MC8.7.2. So I tested one system and I was able to replicate your problem.
    But the problem only occurs when the start-up screen or project screen or whatever Apple call it is set to the smaller screen. If the 4:3 screen is chosen for the OS then when Avid opens you are unable to resize the viewer windows across the larger screen but if the larger screen is chosen as the OS default screen, (the one where your hard drives etc show up), then you are able to resize the viewers across the whole screen.
    I guess you're not using an iMac and have 2 screens attached to your tower but this fix may just work for you. Give it a try.
    Avid DNxIO, 3.5 GHz late 2013 Mac Pro, 64 GB Ram, MC 2018.10 with Symphony option, OS 10.12.6, LaCie 24 TB RAID. 3.5 GHz 6 core Mac Pros x 5, MC 2018.4... [view my complete system specs]
  • Fri, Jan 27 2017 10:33 AM In reply to
    • Hansa
    • Posts 413
    • Points 5,160
    Although I've replacated this problem on MC 8.6.5 too with the Mac OS menu bar on the smaller screen so this may not be of any help to you.
  • Mon, Jan 30 2017 4:55 PM In reply to
    • mmagder
    • Passaic NJ
    • Posts 198
    • Points 2,515
    I just saw your note, but yes on a mac pro, it doesn't seem to work no matter what the start up monitor is, i tried all the versions couldn't get it to go.
    thanks
