Latest post Fri, Jun 9 2017 8:30 AM by Typhon2007. 48 replies.
Page 1 of 4 (49 items) 1 2 3 4 Next >
  • Thu, Dec 22 2016 12:52 PM
    Media Composer 8.7 Render Error/Bug one frame
    we have bugs after rendering clips with color corretion on it. Result aft render is for one frame the color effect does not work, rest of the clip works fine.
    We got this bug with XDCAM and GoPro materiel.
    Rendersetting DNxHD 120, Windows 7, HP Z820, 32GB RAM, AVID MediaComposer 8.7
    An Ideas?
    Best,
    Sergej
  • Thu, Dec 22 2016 1:13 PM In reply to
    • mjolnarn
    • Joined on Wed, Feb 8 2006
    • Sweden
    • Posts 13,346
    • Points 159,335
    Re: Media Composer 8.7 Render Error/Bug one frame
    Hi Sergej , something similar to this
    View this post at http://community.avid.com/forums/p/179713/836745.aspx#836745
    Tomas
  • Thu, Jan 12 2017 5:14 PM In reply to
    • BoomRob
    • Joined on Wed, Mar 9 2011
    • Posts 5
    • Points 75
    I am having render issues involving what looks like digital noise and dropout. Never had a render issue with MC before and I go back to working on 3.5
  • Fri, Jan 13 2017 7:06 AM In reply to
    • mjolnarn
    • Sweden
    • Posts 13,346
    • Points 159,335
    BoomRob:
    Seems to be a render bug with 8.7 , solution for now is to go back to 8,65
    Tomas
  • Fri, Jan 13 2017 1:08 PM In reply to
    • Revenger
    • Joined on Wed, May 11 2011
    • Estonia
    • Posts 74
    • Points 930
    +1
     Digital noise and dropout frames both on rendering and on exporting. Working with DNxHD36
    Looks like a bug of 8.7
    MC 2018.5; HP Z800; Windows 10 Pro 64-bit; Dual Quad-Core Intel(R) Xeon(R) X5570 @ 2.93GHz; 24GB (6 x 4GB) DDR3 1333 ECC RAM; NVIDIA Quadro FX 4800 (driver... [view my complete system specs]
  • Fri, Jan 13 2017 4:45 PM In reply to
    • mjolnarn
    • Sweden
    • Posts 13,346
    • Points 159,335
    I´m doing some own tests here right now that have been succesful so far , I opened up render settings and checkmarked " Disable GPU effect " and this seems to render correct.
    Anyone else ?
    Tomas
  • Fri, Jan 13 2017 10:00 PM In reply to
    • powerfreak
    • Mahopac, NY
    • Posts 316
    • Points 3,940
    yup, had the same problem (and not using color effects), "disable GPU effect" fixed it for me (so far).
    Avid MC8.7 w/ Matrox Mini. Self built system...Dual Xeon E5-2620 CPUs....Supermicro x10DAX MB...64g Ram...Nvidia GeForce GTX1070...G Speed-Q external storage... [view my complete system specs]
    The world is just a cesspool...but all my skies are blue
  • Sat, Jan 14 2017 11:16 AM In reply to
    • Joachim Claus
    • Seeheim-Jugenheim, Germany
    • Posts 909
    • Points 11,640
    I have tested it with a 50p-UHD-material. The project framerate (in format settings) was set to 25 fps. I did not check the box "Disable GPU effect" in Render setting.
    I added a color balance effect and rendered the section. All frames were rendered from first to last.
    I have then swithced the project framerate to 50fps (conform with the source material), and repeated the steps above. Again no frame was left when rendering.
    When in 50fps-mode, I modified one clip (shortened by one frame), so that it becomes an odd number of frames. I repeated the test, and again every frame was correctly rendered.
    Summary: In my test I could not find a bug in render.
    Joachim
    Joachim Claus
  • Sat, Jan 14 2017 12:49 PM In reply to
    • BarkinMadd
    • Ontario, Canada
    • Posts 4,610
    • Points 60,240
    Joachim - try using the Avid CC effect (the one automatically added to the clip when you enter CC mode and make an adjustment). This effect seems to have an issue. Maybe the color balance effect (?) does not use GPU?
    Camera(s) PXW-X70, HDR-FX1, Hero 6 Black | MC 18.11 | QT 7.7.9 | Continuum 2019 | Sapphire 2019 | Mocha Pro 2019 | Titler Pro 6 | Windows 10 Pro x64 |... [view my complete system specs]
    Steve
    ______________________
    www.nelliedogstudios.com
  • Mon, Jan 16 2017 5:17 AM In reply to
    • touviere7
    • Joined on Mon, Mar 15 2010
    • los angeles
    • Posts 587
    • Points 6,635
    confirmation - definitively a render problem with cc applied:   23.976p dnxhd 175x:
    random single frame here and there does not render.
    as mentioned, not using gpu option does solve the problem.
    mc 2018.12 with symphony - win 10 pro64 v.1803 - QT essential 7.7.9 - nVidia gtx1080 OC (411.63) - intel i7 6800k@4.1ghz water cooled by corsair H100i... [view my complete system specs]
  • Mon, Jan 16 2017 4:02 PM In reply to
    • Joachim Claus
    • Posts 909
    • Points 11,640
    BarkinMadd:
    I have tried different color correction settings, including manual adjustments with an UHD-sequence which is rendered to DNxHR SQ, and all frames were rendered correctly.
    I have then tested a 720p50 project with render setting to DNxHD 120. Again, all frames were correctly rendered after applying a color correction.
    Joachim
    Joachim Claus
  • Mon, Jan 16 2017 10:47 PM In reply to
    • touviere7
    • los angeles
    • Posts 587
    • Points 6,635
    update:
    i just tested with the new update 8.7.2
    same problem, same work around when rendering cc.
  • Mon, Jan 16 2017 11:59 PM In reply to
    • Posts 10,018
    • Points 215,695
    Touviere7
    we know... and the engineers are working hard to resolve this....
    marianna
  • Tue, Jan 17 2017 3:57 AM In reply to
    • touviere7
    • los angeles
    • Posts 587
    • Points 6,635
    hi m.
    certainly no doubt about that ;-)
    ...but some people were wondering...
  • Tue, Jan 17 2017 2:40 PM In reply to
    • Posts 10,018
    • Points 215,695
    T...
    Yes I know - its a tough one....  part of the engine and FX aspect of the software.
    Luc and his Team are all over it.
