Latest post Thu, Dec 1 2016 9:26 PM by Marianna. 8 replies.
Page 1 of 1 (9 items)
  • Tue, Nov 29 2016 9:15 PM
    • jdcoletv
    • Joined on Tue, Aug 16 2011
    • Posts 83
    • Points 995
    Export error: avid avid failed changing the clips to the desired quality prior to consolidate
    I am getting this error when trying to export, consolidate or transcode xavc footage. I am just trying to export omfi audio files, but it also brings up this error no matter what I try to do. Never run into this issue before. Running 7.06. Any ideas on how to fix this issue?
    MacBook Pro (15-inch, 2017) running with 16gb and Sierra (10.12.6), Radeon Pro 560 4096 MB. [view my complete system specs]
    Regards,
    Jeremy
  • Tue, Nov 29 2016 9:53 PM In reply to
    • RalphC
    • Joined on Wed, Sep 2 2015
    • Posts 1,833
    • Points 20,230
    • Avid Customer Advocate
      Avid Customer Service
      Avid Employee
    Re: Export error: avid avid failed changing the clips to the desired quality prior to consolidate
    Hi jdcoletv,
    Did you look at this post.
    Regards,
    Ralph
  • Wed, Nov 30 2016 12:55 AM In reply to
    • jdcoletv
    • Posts 83
    • Points 995
    Yes, I did look at the post and it didn't help. It is interesting that I was able to export the files using a different MAC with the same operating system and the same version of MC. Must be specific to the AMA plugin on the MAC or something else (what??). I reinstalled the Sony AMA plugin. Didn't help.
    RalphC:
    Hi jdcoletv,
    Regards,
    Ralph
    Regards,
    Jeremy
  • Thu, Dec 1 2016 4:24 PM In reply to
    • jdcoletv
    • Posts 83
    • Points 995
    So, any ideas? No, I do not have Sony and Nablet AMA plugins running concurrently. Only the Nablet AMA plugins are running. I am at a loss as to how to proceed. While I have solved the deadline issue by using another MAC and AVID setup, the issue still exists. I tried uninstalling and reinstalling 7.06 for MAC with no success.
    Regards,
    Jeremy
  • Thu, Dec 1 2016 5:57 PM In reply to
    • Posts 10,215
    • Points 218,190
    jd..
    Can you post some stats on your Mac and what OS this one has that isnt working.   Wonder if it 7.x related .... checking.
  • Thu, Dec 1 2016 8:15 PM In reply to
    • jdcoletv
    • Posts 83
    • Points 995
    Sure. it is a Mac Pro (early 2008) with a 2x2.8Ghz Quad-Core Intel Xenon with 14GB ram and a Radeon HD 5870 running OS X Yosemite, version 10.10.5.
    Regards,
    Jeremy
  • Thu, Dec 1 2016 9:02 PM In reply to
    • Posts 10,215
    • Points 218,190
    JD
    are you using the plug in
    New in nablet XAVC XDCAM AMA Plugin 4.0.0 ???
  • Thu, Dec 1 2016 9:17 PM In reply to
    • jdcoletv
    • Posts 83
    • Points 995
    So, I just brought in the revised project files used on the other computer to make the exports after doing a bit of editing on them, relinked the AMA files and... I am back in business. No longer do I have the AMA error when exporting or trying to consolidate or transcode. It is back to normal. No idea why, but it works!
    Regards,
    Jeremy
  • Thu, Dec 1 2016 9:26 PM In reply to
    • Posts 10,215
    • Points 218,190
    jd...
    Gremlins.....  weirdness at its best.  thanks for letting me know - I was scratching my head on this one.
