Latest post Tue, Nov 22 2016 12:21 PM by mjolnarn. 24 replies.
Page 2 of 2 (25 items) < Previous 1 2
  • Wed, Nov 16 2016 10:46 AM In reply to
    • mjolnarn
    • Joined on Wed, Feb 8 2006
    • Sweden
    • Posts 13,338
    • Points 159,165
    Re: Source browser wont link to H264 files
    If you have installed Avid without installing Quicktime first the Avid installer might have created a Quicktime folder inside the windows 32 folder and that one will not be removed even if you uninstall both Avid and Quicktime later on.
    So just to search and check , if that is the case I know no better fix than a new os install ....
    Tomas
  • Wed, Nov 16 2016 11:27 AM In reply to
    • MattB
    • Joined on Tue, May 9 2006
    • Shepperton, UK
    • Posts 406
    • Points 5,570
    mjolnarn:
    I was worried someone was going to say that! Starting to come to the same conclusion here too, maybe roll back to Win7 in the process.
    Interestingly, I cant find a 'windows32' folder on my machine!
    I have a support call into Avid in the meantime.
    MattB
    Edit 1:- Intel Core i7 960 3.2 GHz (self build) Gigabyte GA-X58A-UD3R Mobo 24GB Corsair Vengance DDR3 1600Mhx memory NVIDIA Quadro 4000 (Nvidia driver... [view my complete system specs]
    Matt B
  • Wed, Nov 16 2016 11:41 AM In reply to
    • mjolnarn
    • Sweden
    • Posts 13,338
    • Points 159,165
    MattB:
    mjolnarn:
    I typed fast, thought you knew , the full path is windows / system32
    Tomas
  • Wed, Nov 16 2016 11:45 AM In reply to
    • MattB
    • Shepperton, UK
    • Posts 406
    • Points 5,570
    mjolnarn:
    I did look there - no QuickTime folder though
    Matt B
  • Wed, Nov 16 2016 12:11 PM In reply to
    • mjolnarn
    • Sweden
    • Posts 13,338
    • Points 159,165
    MattB:
    mjolnarn:
    Ok, now we have checked that one, how about disk properties for the external drive , do you have read and write permissions for all
    Tomas
  • Wed, Nov 16 2016 12:20 PM In reply to
    • MattB
    • Shepperton, UK
    • Posts 406
    • Points 5,570
    mjolnarn:
    Yes, I thought of that. Permissions OK, but to double check I copied files to internal media drive. Still no joy linking.
    Matt
    Matt B
  • Wed, Nov 16 2016 12:24 PM In reply to
    • mjolnarn
    • Sweden
    • Posts 13,338
    • Points 159,165
    Ok ...
    In one post you say clean install of Win 10 and in another you say update , you also mentioned roll back to win 7 , that not should be possible if it was a fresh Win 10 install .
    So, what is the situation , there is a command in win 10 to install fresh .
    Tomas
  • Wed, Nov 16 2016 12:29 PM In reply to
    • MattB
    • Shepperton, UK
    • Posts 406
    • Points 5,570
    mjolnarn:
    Ok ...
    No - I updated to Win10 with free MS offer, then clean installed from downloaded image file. I cant 'roll-back' as such. Id have to use my old install media and clean install with that.
    Matt B
  • Tue, Nov 22 2016 11:16 AM In reply to
    • MattB
    • Shepperton, UK
    • Posts 406
    • Points 5,570
    mjolnarn:
    Tomas - you were right, back to a clean OS install has done the trick (Back to Win 7). Did a few rounds of correspondence with Avid support, but in the end I had to 'bite-the-bullitt'.
    All good now. Thanks
    MattB
    Matt B
  • Tue, Nov 22 2016 12:21 PM In reply to
    • mjolnarn
    • Sweden
    • Posts 13,338
    • Points 159,165
    Sorry that you had to do that Matt but I almost guessed that you would need to , nice that it works now
    Tomas
