Latest post Tue, Apr 12 2011 11:20 PM by Ari Zlatin. 2 replies.
  • Tue, May 16 2006 6:06 PM
    Ideas for fast rendering
    I frequently use Avid FX to generate FX with lots of lighting and particles, and get long render times. Marquee takes advantage of graphics processing, but as far as I can tell, FX does not -- it uses only the CPU.
    Is there a setting to fix this?
    If not, do any of you use render farms or similar to get shorter render times?
    P4, 2.80 GHz, 2 GB RAM, 160 GB System Drive, 228 GB Video, 2 x 100 GB Firedock drives, 1 x 300 GB additional media drive, 160 GB WD external Firewire drive... [view my complete system specs]
    Manny "Lock it. Episode 5 airs tomorrow." "But you gave me Episode 4. This is 4." "<blink>Make some coffee."
  • Tue, May 16 2006 6:19 PM In reply to
    Re: Ideas for fast rendering
    I gave up on trying to get faster rendering Smile [:)]
    I went through a period of testing to try to get some OpenGL hardware acceleration from AvidFX and my Quadro 3400 FX.
    If I remember correctly, Xpress Pro and/or the Mojo would lock the OpenGL hardware acceleration from AvidFX which was a shame because IMHO AvidFX needed access to it more than the Composition window.
    When I ran AvidFX on its own, I had access to the OpenGL hardware acceleration and it ran a lot quicker. I didn't test the rendering of AvidFX when it was run standalone though. That might be something to try.
    Click on Web Address [view my complete system specs]
  • Tue, Apr 12 2011 11:20 PM In reply to
    • Ari Zlatin
    • Joined on Fri, Jun 13 2008
    • Lincoln, CA
    • Posts 41
    • Points 520
    Is there a way to make Avid MC5.5.1 use GPU for rendering Boris RED 4.3.3?
    ASUS PRIME Z390 MB, 32 GB DDR5, SSD DRIVE, EVGA GTX 1080, WINDOWS 10-64 bit Professional, 2k MONITOR [view my complete system specs]
