Latest post Sun, Nov 8 2009 3:59 AM by cdabrowski. 3 replies.
  • Fri, May 12 2006 10:39 PM
    • AvidNathan
    • Joined on Fri, May 12 2006
    • Posts 2
    • Points 30
    Avid DVD Error - DVDErr, -20404
    When building video files/disk image/disk:
    I get the error "Could not complete the last command because:  The data rate of this file is too high for DVD.  You must replace the file with one of a lower data rate. (DVDErr,-20404)"
    The data rate for my video is 7782Kbps which seems well below the max rate of 9000Kbps.
    Has anyone else experienced this error?
    Avid Xpress Pro HD with Studio 5.1 PC Windows XP Home [view my complete system specs]
  • Mon, May 15 2006 9:36 PM In reply to
    • AvidNathan
    • Posts 2
    • Points 30
    Re: Avid DVD Error - DVDErr, -20404
    I re-compressed my video at 6000Kbps which fixed that problem but then gave me another error:
    "Use of invalid editor:AuthorCore::PGCEditorBase"  I couldn't find any threads on this error, but when I turned off the OpenDVD option the project complied and burned fine.
    Just wanted to update the post incase someone else was having similar problems.
  • Fri, Oct 13 2006 4:28 PM In reply to
    • jims
    • Joined on Thu, Oct 12 2006
    • Posts 5
    • Points 60
    I have the same problem. Is there any solution?
    My system is  runing toolkit 5.2.1 with QT 7.0.3. Using sorenson squeez 4.3.3.
    I tried to lower data rate to 6218Kbps total, but the error is still there.
  • Sun, Nov 8 2009 3:59 AM In reply to
    Thanks for posting your updates about this.  Been having the same "Could not complete the last command because:  The data rate of this file is too high for DVD.  You must replace the file with one of a lower data rate. (DVDErr,-20404)" problem myself.
    What I found is that the error is related to the movie file I was using for the menu.  The video was encoded at 7800k with AC3 at 384k.  Movie files I'm using as regular movies, not menus, work fine.  So once I re-encoded the menu video to 7000k still with AC3 at 384k, then everything worked again.
    Thanks again.
    CD
