Latest post Thu, Nov 22 2018 10:34 AM by maason. 10 replies.
Page 1 of 1 (11 items)
  • Wed, Sep 14 2016 5:31 PM
    • Marty
    • Joined on Sat, Dec 3 2005
    • Berlin, Germany
    • Posts 921
    • Points 10,705
    Play Multicam Sequences in Source Monitor
    I can't play sequences in Multicam mode on the source side, only on the record side. Why?!?
    It's possible with group clips but not with sequences - Is this a bug or feature request? I see no reason why it shouldn't work and it would make my workflow so much better when working with sequences instead of individual group clips as the source.
    all different setups in various editing suites. my own: MC 2018.2, OSX 10.12.6, iMac (Retina 5K, 27-inch, 2017), 4,2 GHz Intel Core i7, 40GB RAM, Radeon... [view my complete system specs]
    www.film-editing.de
  • Thu, Sep 15 2016 1:46 AM In reply to
    • jef
    • Joined on Sun, Feb 26 2006
    • Maryland
    • Posts 3,405
    • Points 41,085
    Re: Play Multicam Sequences in Source Monitor
    Can you explain a bit more?
    The whole multicam workflow is designed to have a group clip made, cut the group clip into a sequence, activate Multicam mode and then make shot selections while the the camera splits roll in the source window and the line cut is in the record window.
    Not sure how you see this working with a sequnce in the source window.
    Guess I would have to try this to see.
    Is this for refineing edits?
    Just trying to understand your need.
    Jef
    Jef Huey
  • Thu, Sep 15 2016 4:06 AM In reply to
    • tpowell
    • Joined on Wed, Dec 10 2014
    • Posts 36
    • Points 415
    I think this is related to how other NLE's operate. They use a stacked sequence which allows for slipping and sliding individual clips if the sync isn't right, or having multiple clips on a single track (for example if the camera starts and stops). Overall, it is a better way to do it, IMHO.
  • Thu, Sep 15 2016 6:10 PM In reply to
    • Marty
    • Berlin, Germany
    • Posts 921
    • Points 10,705
    Thanks. I have a scene with 2 cameras, all synced as group clips.
    When I'm doing my selects sequences, I want to watch the footage in multicam mode so I see both cameras simultaneously on the client monitor. It's possible when I'm loading the group clip as the source.
    But I like to work with sequences as the source instead of the individual group clips. Let's say I have 12 different takes, I prepare a sequence with all the takes in a row. Then I load this "rushes sequence" into the source monitor and do my selects. But I can't watch both cameras on the client monitor in Multicam mode on the source side, it's a pitty.
    www.film-editing.de
  • Thu, Sep 15 2016 7:01 PM In reply to
    • Marty
    • Berlin, Germany
    • Posts 921
    • Points 10,705
    Another scenario would be when I have tons of rough material and I did a selects sequence.
    Now, I want to use that selects sequence as my source for the edit sequence and I want to watch both cameras simultaneously on the client monitor - it's not possible.
    www.film-editing.de
  • Sun, Sep 18 2016 10:00 PM In reply to
    • jef
    • Maryland
    • Posts 3,405
    • Points 41,085
    Here is another maybe wild idea.
    Have you considered doing a Multi Group from your Selects Sequence?
    No idea if that would get you where you want to go ....
    Jef
    Jef Huey
  • Mon, Sep 19 2016 1:16 AM In reply to
    I like that idea... I'd like it more if MC had a one-button tool that instantly changed a Sequence into a Multi-Group.
    I'd be curious if MultiGroup works to show all angles in Source Monitor.
    We often make MP4 screeners of our Quad splits (or more angles) with all kinds of BITC for producers,etc. It is possible to anticipate that - and at the outset, add another "replaceable"/relinkable Video Clip to a group clip, and then later Relink the BITC PiP to the same Groupclip from whence it originally came. That's a workaround.
    Ive done this sort of thing with audio, too. It's the closest we can get to editable Group clips.
  • Mon, Sep 19 2016 6:26 PM In reply to
    • Marty
    • Berlin, Germany
    • Posts 921
    • Points 10,705
    Seems like it's not possible, yet. Maybe a feature request. Found this old thread:
    http://community.avid.com/forums/p/102192/719402.aspx
    What about feature requests - should I write Avid support? It seems like the Feature Request Forum isn't so alive.
    www.film-editing.de
  • Thu, Sep 22 2016 8:24 AM In reply to
    • Marty
    • Berlin, Germany
    • Posts 921
    • Points 10,705
    Answer from Avid-Support:
    At the moment, MCCET-1499 View Multicam sequence in quad split form into the source monitor has been logged as a feature request into the engineering team.
    www.film-editing.de
  • Tue, Nov 20 2018 11:44 AM In reply to
    • Leo
    • Joined on Mon, Feb 14 2011
    • Berlin
    • Posts 38
    • Points 360
    is it still not possible? or am i doing something wrong?
    all the best!
    2017 iMac i7 24GB RAM 8GB Radeon 580. OSX Mojave. 2011 MBP i7 16GB RAM AMD HD 6750M 1GB Video. OSX 10.11.5 Avid MC 8.8.0 [view my complete system specs]
  • Thu, Nov 22 2018 10:34 AM In reply to
    • maason
    • Posts 1
    • Points 5
    This was two years ago. Still not possible... Avid-support???
