Latest post Thu, Sep 22 2016 9:11 AM by Roland Achini. 12 replies.
Page 1 of 1 (13 items)
  • Sat, Jul 30 2016 2:17 PM
    Audio Render problem with MC 8.6.1
    (1) After having upgraded from MC 8.6 to 8.6.1 Audio Dissolve cannot be rendered (messgae: No effects found to render). Rendering between In and Out also doesn't work.
    (2) If I add an Audio Dissolve AND a Video Dissolve, Rendering works for Audio and Video, but a messgae says "1 Effect to Render".
    (3) If I want to have only Audio Dissolves, I have to use approach (2) and thereafter to delete the Video  Render.
    MB: ASUS P6TD Deluxe, ATX, Intel X58, QPI 6.4GT/s, Intel LGA1366, 6xDDR3 1600MHz, PCI-E V2.0, On-board Soundkarte. CP: Intel Core i7 920 (2.66 GHz) Quad... [view my complete system specs]
  • Mon, Aug 1 2016 9:21 AM In reply to
    Re: Audio Render problem with MC 8.6.1
    Does nobody else experience this problem, or am I doing a mistake?
  • Mon, Aug 1 2016 9:42 AM In reply to
    • mjolnarn
    • Joined on Wed, Feb 8 2006
    • Sweden
    • Posts 13,346
    • Points 159,345
    Could you maybe post a screengrab of your timeline Roland
    Tomas
  • Mon, Aug 1 2016 11:11 AM In reply to
    Sorry, I do not know how to insert an jpg image (screengrab). Could you please tell me?
    Roland
  • Mon, Aug 1 2016 11:45 AM In reply to
    I can confirm this action (or non-action). If in Quick Transition, you can Add and Render but if you try to render an unrendered audio mix, you can't. Tried the render button, 'render at position' and 'render I-O'. Mac 8.6.1. Mac OS 10.11.6 (I know, not qualified!).
    iMac i5 27", 40GB RAM, OS 10.14.6 with Symphony 2019.12, BlackMagic mini monitor. MacBook Pro, 16GB RAM with OS 10.13.6 with MC 2018.12.12 and BMD... [view my complete system specs]
  • Mon, Aug 1 2016 1:45 PM In reply to
    A fellow MC user, Toni "Askor" on a German Forum
    http://www.hdtvschnitt.de/forum/viewtopic.php?f=72&t=3453&p=30034#p30034
    has solved this problem:
    He just adds a Quick Audio Dissolve and clicks on "Add and Render".
  • Tue, Aug 2 2016 7:11 PM In reply to
    That is not a solution (and I said that in my last post). If we want to change the duration or position, we can't render without applying a new effect from scratch. Mind you, why render an audio cross-fade anyway?
  • Tue, Aug 2 2016 9:18 PM In reply to
    • Posts 10,899
    • Points 227,010
    Roland and Roger
    Created a case 03008231 - reproduced ... and asked that it be logged as a bug.
    I added you both to the case so you each will get emailed by avid on this. I also told them that the "fix" is NOT a si=olution as you indicate Roger. stand your ground.
    Stand by
  • Wed, Aug 3 2016 4:47 PM In reply to
    • abacaxi
    • Joined on Thu, Mar 17 2011
    • Posts 1
    • Points 15
    Hi, I'm experiencing the same problem here, really a mess. I've got tons of unrendered crossfades and taking the "add and and render" road for every single effect will be much too time-consuming (and annoying, too). I also get an "unavailable effect" on all audio clips. What is it? Am I missing something? Really would appreciate some help on these issues.
    Thx
    Dirk
  • Mon, Aug 8 2016 1:10 PM In reply to
    A further observation: I tried rendering a dissolve on video and matching audio mixes at the same point and even though the dialogue reports '1 Effect to render', all three get rendered.
  • Wed, Aug 10 2016 3:54 AM In reply to
    • Sylvain P
    • Montreal, Quebec, Canada
    • Posts 1,488
    • Points 17,595
    I can also confirm the issue. I get the same message about no audio effect to render. But they will render if a video effect is present.
    Media Composer 2018.12.2 (Symphony Option), ASUS P8P67 Deluxe, Intel i7 2600k, 16G DDR3-1600, PNY NVIDIA Quadro 2000 (353.82), Windows 10 Pro. Boris Red... [view my complete system specs]
    Sylvain Primeau
    Self-employed worker - Les productions Primeau Medias
    primeaumedias.com
    Radio-Canada/CBC news editor
    cbc.ca / ici.radio-canada.ca
  • Wed, Sep 21 2016 4:54 PM In reply to
    • biegert
    • Posts 19
    • Points 245
    I've just discovered this problem, too.
    T
  • Thu, Sep 22 2016 9:11 AM In reply to
    This bug is removed in MC 8.6.2 and 8.6.3.
