Latest post Wed, Jul 20 2016 9:44 PM by Lukas Boeck. 1 replies.
Page 1 of 1 (2 items)
  • Wed, Jul 20 2016 5:18 PM
    • Andy
    • Joined on Wed, Sep 8 2010
    • Brooklyn, NY
    • Posts 27
    • Points 415
    How do you add more effects like TRIM TO FILL after using STABLIZE
    I have a clip that I added Stablize too. Worked like a charm!
    When i try to add TRIM TO FILL - It says EFFECT DOES NOT APPLY
    It also blocks it in reverse. I can't stablize a clip after it's been Trim To Fill.
    Is there a work around for this in AVID?
    Windows 7 Professional Intel Core i7 CPU 2.80GHZ 16 GB Ram video card:nvidia quatro FX 580 Media Composer 5 -> 6 [view my complete system specs]
    Filed under: ,
  • Wed, Jul 20 2016 9:44 PM In reply to
    • Lukas Boeck
    • Joined on Fri, Jul 31 2015
    • Austria
    • Posts 466
    • Points 5,480
    Re: How do you add more effects like TRIM TO FILL after using STABLIZE
    time effects like trim to fill need to be applied directly on the clip.
    stabilize after.
    You can look below any effect with "step in" and apply another effect.
    stabilize would need to run again if you make changes below it.
    trim to fill at the bottom of a pile will still work, even thou' you don`t see it.
    MC 8.4.4 Cusom bulid Supermicro X9SRL-F, 32 Gig Ram, 3ware 9750 6x6TB Seagate EC Drives, LSI 9207 + LTO-6, Mojo DX, Artist Color, Flanders CM240, GTX 1070... [view my complete system specs]
