Latest post Wed, Aug 3 2016 5:12 PM by JeremyKezer. 1 replies.
Page 1 of 1 (2 items)
  • Wed, Jun 29 2016 1:55 PM
    • Francesco
    • Joined on Wed, May 16 2012
    • Pisa - Italy
    • Posts 68
    • Points 665
    Plugin #0: Failed to get enumeration interface
    Hi To all
    I'm developing my custom plugin and testing it with Media Composer 8.5.3.  I start from the HWSDK_Generic
    plugin supplied in the SDK and changed the subsequent GUID :
    Module ID : MID_HWSDK_Generic (renamed in MID_HWSDK_blt)
    Vendor ID : ACFVendorID_HWSDK_Generic (renamed in ACFVendorID_HWSDK_blt)
    Class ID  :  CLSID_HWSDK_Generic_MainComponent  (renamed in CLSID_HWSDK_blt_MainComponent)
    implementation ID : ACFCompID_HWSDK_Generic_Component (renamed in ACFCompID_HWSDK_blt_Component)
    (By the way : I found that the MID_HWSDK_Generic and ACFVendorID_HWSDK_Generic are defined twice
    with two different GUID once in file HSDK_Generic.h and in HSDK_Generic_Plugin.cpp).
    Other changes I made are:
    sPluginVendor, sPluginName and sPluginDescription according to my company name
    In this case I receive the error in subject, mainly in the ACFStartup method:
    ACFAPI ACFStartup (IACFUnknown * pUnkHost)
        BEGIN_ACF_METHOD;
        if (!pUnkHost)
            return ACF_E_INVALIDARG;
        ACFRESULT result = ACF_OK;
        ACFPtr<IACFSingletonManager> pSingletonManager;
       OutputDebugStringA("ACF Startup called");
        result = pUnkHost->QueryInterface( IID_PPV_ARG(IACFSingletonManager, pSingletonManager.outArg()) );
        if ( ACFSUCCEEDED(result) )
           OutputDebugStringA("ACF Startup : singletonManager ok");
            // Create the singleton component now without a class factory.
            ACFPtr<IACFUnknown> pSingletonWithoutFactory;
            acfcheck( HWSDK_Generic_MainComponent::ACFCreate(pUnkHost, NULL, IID_PPV_ARG(IACFUnknown, pSingletonWithoutFactory.outArg())) );
           OutputDebugStringA("ACF Startup : ACFCreate ok, adding singleton");
            acfcheck( pSingletonManager->AddSingleton(ACFCompID_HWSDK_Generic_Component, CLSID_HWSDK_Generic_MainComponent, pSingletonWithoutFactory) );
          OutputDebugStringA("ACF Startup : addsingleton ok");
        END_ACF_METHOD;
    I insert the OutputDebugString in order to detect where method fails. I See the sequence of messages:
    ACF Startup called
    but I didn't see the last message (ACF Startup : addsingleton ok) and the result is in Failed to get enumeration
    interface. The log file reports:
    Open I/O discovered 2 plug-ins and will enumerate them for HWInstances:
      Plugin #0 ( Name: HWSDK_BLT, Version: 2.0 )
    VDMerr [80040111] @ ..\..\src\HWSDK.cpp | Line# 350 :: Error Code: 80040111  Msg: Error Code: result  Msg: "  Plugin #0: Failed to get enumeration interface."
    Please can you help in solving ?
    (I'm using VS2015 community on Windows 10 64 bit)
    Regards
  • Wed, Aug 3 2016 5:12 PM In reply to
    Re: Plugin #0: Failed to get enumeration interface
    Francesco,
    Sorry for the late reply but I hadn't seen your message until now.  Have you gotten past this hurdle?
    Jeremy
