Latest post Sat, Jun 18 2016 6:43 AM by Cagey. 2 replies.
  • Sat, Jun 18 2016 1:40 AM
    • markyramone
    • Port Lincoln, Australia
    • Posts 143
    • Points 2,030
    Import .mov with alpha channel?
    I've been sent an animated graphic with alpha channel as a Quicktime Pro Res movie. How do I import this, keeping the alpha channel? I've tried 'invert", "do not invert"and "ignore" in the Import settings dialogue box. Each option results in the same, a normal clip that does not key over a lower video track.
    Avid Media Composer 8.8, Intel Core i7-4790, 3.6 GHz, 16gb RAM NVDIA GeForce GTX 960 Microsoft Windows 10 Home 64 bit [view my complete system specs]
  • Sat, Jun 18 2016 3:10 AM In reply to
    Re: Import .mov with alpha channel?
    Do you have Photoshop?
    If so you could try opening the movie in Photoshop
    Exporting the movie from Photoshop as an image sequence selecting the appropriate alpha information.
    Import image sequence into MC.
    Worked here with non alpha ProRes .mov  (sorry no alpha .mov to test with readily available)
  • Sat, Jun 18 2016 6:43 AM In reply to
    • Cagey
    • Vista, CA
    • Posts 319
    • Points 3,990
    If you have access to After Effects you can use this guide to export as DNxHD with Alpha Channel and then Fast Import:
    Importing DNxHD with Alpha from After Affects
    Keith
    MC8.6.1, Z420 Xeon E5-2670, 32GB RAM, GeForce GTX 1080, DIGI002, Win 10 Pro 64-bit [view my complete system specs]
    There are 10 kinds of people in the world, those that get binary, and those that don't.
