Latest post Mon, Aug 6 2018 1:06 PM by Jaucker. 4 replies.
  • Fri, Jun 10 2016 7:01 PM
    • jcmcnamee
    • Brooklyn, NY
    • Posts 222
    • Points 2,390
    trim to fill on frameflex clips
    It doesn't work but adding a regular timewarp does. Any reason we can't use the trim to fill on these? Running 8.5.3 on 10.11.4.
    Media Composer 2018.5 / OS 10.14.1 27" iMac [3.5 GHz Intel Core i7, 32 GB ram, NVIDIA GeForce GTX 780M 4GB] [view my complete system specs]
  • Wed, Sep 21 2016 11:31 PM In reply to
    • jschnaudt
    • Joined on Wed, Sep 7 2016
    • Posts 3
    • Points 25
    Re: trim to fill on frameflex clips
    Same problem and workaround here, but this is significantly slower than the trim to fill effect. Any updates?
    Filed under: ,
  • Tue, Jul 31 2018 5:21 PM In reply to
    • Jaucker
    • Joined on Wed, May 2 2018
    • Posts 4
    • Points 30
    I just updated to 2018.7 which in the Read me bug fixes this was one of them..... However, trim to fill is still not working on clips with spatial adpters.
    I also realize now this is for MAC so my apologies. However the error still applies to my windows as well.
    Windows 10 Pro Version 10.0316299 Build 16299, Intel Core i7-8700k CPU @ 3.70 GHz, GTX 1080 Ti [view my complete system specs]
  • Mon, Aug 6 2018 12:42 PM In reply to
    • Posts 10,151
    • Points 217,275
    Josh
    What OS are you using?  Also how were the clips created prior to attempting to Trim to fill?
    Also I cant find your System ID so can you private message me please and send it along.
  • Mon, Aug 6 2018 1:06 PM In reply to
    • Jaucker
    • Posts 4
    • Points 30
    I created the clips by first AMA linking to them and then transcoding them to DNxHR.
    I sent you the requested info via email. I forgot to include the above information.
    Thank you for your help!
