Latest post Fri, May 20 2016 9:45 PM by Bill_Moede. 2 replies.
  • Fri, May 20 2016 6:16 PM
    • Bill_Moede
    • Joined on Fri, Aug 16 2013
    • Posts 8
    • Points 85
    Adding Metadata to Exported OP1a File?
    Hey everyone.  I know this might be kind of off topic, but was hoping for some advice or hints.  Our agency is changing the way we deliver videos for on-air playback.  We used to send ProRes .mov files and Master Control would take care of getting them onto the playout server.
    Now, we are being asked to deliver broadcast ready OP1a .MXF files.  That's not a problem, I know how to create those.  The problem is we are also being asked to add additional metadata to the files, including TRT, Program name and description and a custom identifier.
    Does anyone know of any programs for Mac that can insert metadata into an MXF file?  I've found exiftool, but that's a command line program and I want to try to make this as easy as possible for the team here.  Most of the other programs I've found are designed for stills and not video files.
    We're running 2 MC seats, v7 and v8.3 on MacPros running OS 10.10.
    Thanks much for your help and advice!
    -Bill
    Filed under: , , , ,
  • Fri, May 20 2016 8:33 PM In reply to
    Re: Adding Metadata to Exported OP1a File?
    Would the AMA File export using a Shim work for you?  (an AS-11 export options screen shot attached)  For more details open MC helps and search on Shim. I believe in the UK there are programs that will add even more data to AS-11, AS-02 files.
  • Fri, May 20 2016 9:45 PM In reply to
    • Bill_Moede
    • Posts 8
    • Points 85
    Andrew, I'll certainly take a look and see if that will work.  I had never heard of a Shim before, so I guess I have some homework to do.
    If anyone else has suggestions, I would love to hear them!
    Thanks again!
    -Bill
    **EDITED TO ADD: Andrew, if I'm reading this correctly, the AS-11 spec calls for an AVC-Intra or AVC LongGOP or MPEG-2 encoded file @ 100Mbps for HD delivery.  Our delivery requirements are XDCam @ 50Mbps.  So I don't think that will work.  Will continue reading to learn some more about it.  Cheers...
