Latest post Wed, May 25 2016 8:26 PM by Dalida. 11 replies.
Page 1 of 1 (12 items)
  • Tue, May 3 2016 11:27 AM
    • benholden
    • Joined on Mon, Apr 13 2015
    • London, UK
    • Posts 37
    • Points 445
    XAVC/XDCAM (PDZK-MA2) Plug-in for Avid 3.50 Update
    Plug-in now supports (offically) MC v8.5 and OSX 10.11:
    Added support for Media Composer V8.5
    Added support for Windows 10
    Added support for Mac OS 10.11
    Changed XAVC Encoder to Sony’s Encoder (Supporting XAVC 4K Long 422 10bit Export
    Download: http://www.sonycreativesoftware.com/download/pdzk-ma2 Avid support: http://avid.force.com/pkb/articles/en_US/Download/en394827/
    Avid MC v2018.7 / Mojo DX / Mac Pro 6.1 late 2013 / MacOS 10.12.6 / 64GB Memory / AMD FirePro D500 / 3GHz 8 Core Intel Xeon E5 / LG 34UC98 Ultra Wide Display... [view my complete system specs]
  • Mon, May 9 2016 8:46 PM In reply to
    • bas3000
    • Joined on Wed, Dec 24 2014
    • Posts 12
    • Points 130
    Re: XAVC/XDCAM (PDZK-MA2) Plug-in for Avid 3.50 Update
    My heart skips a beat whenever there's an update for this AMA plugin. But still no XAVC-S support... No
  • Mon, May 9 2016 11:14 PM In reply to
    bas3000:
    Does this convey the impression that there is something basically flawed in this codec prevents its use as a reliable /repeatable "Link" format?
    IMO Sony are one of the best at quickly adding AMA plug-ins and regularly updating them. They have shown no interest in providing an XAVC-S plug-in (apart from a Sony rep saying here on the forums once that it MAY be looked at after the professional XAVC plug-in was fully sorted.) This would lead me to believe that it is unlikely that the XAVC-S codec, in its original form, will become a supported Link plug-in.
  • Thu, May 19 2016 7:13 PM In reply to
    • bas3000
    • Posts 12
    • Points 130
    Yes, it absolutely does.
    I'm looking at less than optimal performance in Premiere Pro with the XAVC-S Codec, so it might be basically flawed in some way. I've gotten quite used to sending all my XAVC-S footage through 'Squeeze' though :)
    -Bas
  • Fri, May 20 2016 4:07 PM In reply to
    • Dalida
    • Posts 10
    • Points 100
    Hi, do you know if there is any support for a Camera sony a7rII in Avid? I can't find an AMA plug-in for it. Thank you.
  • Fri, May 20 2016 6:59 PM In reply to
    • Mike
    • Joined on Wed, Jun 29 2011
    • PA
    • Posts 124
    • Points 1,365
    Dalida:
    I'm starting to grow impatient too, i've been converting before transcoding into avid
    *0SX 10.14.3 *MC Ultimate 2018.12.3 *iMacPro (2017) 2.3 GHz Intel Xeon W-18cor*128 GB 2666 MHz DDR4*Radeon Pro Vega 64X 16 GB *AJA IO4KPlus *AVID ISIS... [view my complete system specs]
  • Mon, May 23 2016 8:59 AM In reply to
    • benholden
    • London, UK
    • Posts 37
    • Points 445
    Having looked at the camera spec, it records in either XAVC S or AVCHD. XAVC S and Avid/MC don't work. XAVC S is seen as a more 'consumer' codec (there's probably a bit more to it but thats the basis of it). For a more detailed disscussion, info and work arounds, read through this forum post - http://community.avid.com/forums/t/129982.aspx?PageIndex=1
    The other work around is to use the AVCHD recording codec option plus the AVCHD AMA MC plugin (installed with MC since MC v6....) but, i believe, that wont give 4K camera recording option, only 1080HD.
    To pull a few options out of the linked forum post, you can use compression software (Squeeze etc) to transcode/convert the XAVC S codec. There's also a AMA plugin from Drastic (can't link directly to the MC XAVC S only option but this web page will help) http://www.drastic.tv/productsmenu-56/mediareactorlist/mediareactor-workstation#special-features.
    Hope that help/answers your question.
  • Mon, May 23 2016 7:41 PM In reply to
    • Dalida
    • Posts 10
    • Points 100
    Thank you Ben, I am going to check the options you are giving me. Right now, I am transoding with Brorsoft Video Converter for Mac and it works but It would be great to have an AMA Plug-in for this codec.
    Have a great day :)
  • Mon, May 23 2016 10:32 PM In reply to
    I'd strongly recommend against using the tool you refer to here - as it's among one of many others that share some shady practices (Source: "Speaking With Spammers" - a few years old, but still VERY relevant).  One reputable tool is EditReady, by Divergent Media.  It features options such as re-wrapping without a transcode, or transcoding to DNxHD/DNxHR/ProRes and others, and it maintains metadata such as timecode.
  • Tue, May 24 2016 12:39 AM In reply to
    I also prefer EditReady.
  • Wed, May 25 2016 3:07 PM In reply to
    • Mike
    • PA
    • Posts 124
    • Points 1,365
    Dom Q. Silverio:
    what are the actual resoluitions in edit ready for dnx low, med, high?
    thanks
  • Wed, May 25 2016 8:26 PM In reply to
    • Dalida
    • Posts 10
    • Points 100
    Thank you for the recommendation, I will try it, maintain the metada is very important. :)
