Latest post Wed, Apr 18 2007 12:47 AM by Triny Roe. 6 replies.
Page 1 of 1 (7 items)
  • Sun, Apr 23 2006 8:16 AM
    • Edit One
    • Bangkok, Thailand
    • Posts 86
    • Points 1,145
    Sorenson Squeeze Error
    Using standard 'Send To" option from Xpresss Pro to Avid Studio/Encoding for AVID DVD by Sonic and then starting the 'squeeze' process in Sorenson Squeeze for DVD PAL (Small or large) I get the following error after the Squeeze timeline reaches about 60% complete:
    "The movie file "" could not be found. Without this file, the movie cannot play properly"
    I am also getting a MetaSync Publisher error that says:
    "Error(s) were encountered while processing the specifies AAF file(s). View log for details"
    The log (mentioned above) indicates an error opening the aaf file for the project.
    When I cancel the first error mesage in Sorenson I then get another error saying:
    There was a compression srror while compressing the file <filename>..Error:0x8003001e
    I have updated the MetaSync Manager and MetaSync publisher to the latest version.
    This has only occurred since installing the download version of Xpress Pro v5.2.4. I do not have the 5.2.4 install DVD with the new DVD creation software (still on AVID DVD by Sonic)) but I don't think that is the issue as I don't get even past Sorenson.
    Any ideas would be warmly welcomed.
    Thanks.
    HP XW8400 2 x Xeon Dual Core 3.06Ghz Processors, 4Gb ECC RAM, Quadro 3500 GFX Card, Primary SATA 250Gb Dual Boot Vista Business D:HP Recovery Ext... [view my complete system specs]
  • Mon, Apr 24 2006 8:03 AM In reply to
    • Cagey
    • Vista, CA
    • Posts 318
    • Points 3,985
    Re: Sorenson Squeeze Error
    I contacted Sorenson about this error and they confirmed that they are having problem with Quicktime Reference files from Avid.  The suggested installing Quicktime 6.5.1.  That did not fix my problem, but I discovered a work-around, changing the field order to bottom field first allowed me to get past the error.  This is odd because the footage that caused the issue was progressive (24p).  I'm hoping that Sorenson has a fix in their next release.
    Good Luck!
    Keith
    MC8.6.1, Z420 Xeon E5-2670, 32GB RAM, GeForce GTX 1080, DIGI002, Win 10 Pro 64-bit [view my complete system specs]
    There are 10 kinds of people in the world, those that get binary, and those that don't.
  • Mon, Apr 24 2006 7:32 PM In reply to
    I had exactly the same problems !  Avid support was totally lost and unable to help Embarrassed [:$].
    Here are the steps I took, they are probably not all necessary, but at least the problem does not exist anymore.
    1. Obtain the 5.2.1 complete upgrade disk (not the downloaded version).
    2. Uninstall Avid Xpress Studio completly.
    3. Reboot
    4. Delete manually the Avid installation directory
      • Normally C:\Program Files\Avid
    5. Defragment drives (notably your system drive and the drive(s) where you store your working files.)
    6. Reboot
    7. Disable and remove from the taskbar tray any utility program which could in anyway interfere with Avid
      • Audio utility programs (eg Creative)
      • Video managers (eg : Intervideo WinDVD)
      • Any Chat tools like MSN messenger
      • Quicktime
      • Acrobat
      • etc
    8. Now install 5.2.1 using all the default settings.
    9. Do not install 5.2.4  This is not for studio
    I hope that this will help.
    MC 3.1.3, Pro Tools LE 8.0cs3, self built system : Asus P5Q3 Deluxe, 4Gb ram, Intel Core 2 Quad Q9450, PNY Quadro FX 3700 - 512 Mo, XP sp2, MBox 1 [view my complete system specs]
  • Mon, Apr 24 2006 10:25 PM In reply to
    • johnnytex
    • Joined on Tue, Apr 18 2006
    • Dallas
    • Posts 146
    • Points 1,820
    I was getting the same error and here's what Sorenson said:
    This problem is an issue that is happening with Squeeze 4.3 and QuickTime 7.*. There are 2 solutions. The easiest is to import the mov reference file into squeeze and use the link audio function in Squeeze to manually attach the aiff audio file. (I added a screen shot showing where to get to the link audio option.)Once you have added the source file to the batch area right click on the file and select link audio.
    Then search for the aiff file and select it.
    If that does not work the other solution is to downgrade your copy of QuickTime to 6.5.1. To do that download the 6.5.1 installer from the apple website. Then uninstall QuickTime 7 and install 6.5.1.
    http://www.apple.com/support/downloads/quicktime651.html
    We will have an update out later this month that should resolve this issue.
    Andy Engberson
    Technical Support
    Sorenson Media
    4179 Riverboat Road Ste. 208
    Salt Lake City, Utah 84123
    Additional support is also available on the Squeeze Forum http://p219.ezboard.com/bsorensonsqueeze
    Sys 1: z800 Windows 10 Pro 64 48g Ram GTX 1070 MC Latest QT 7.7.9 Nvidia 375.98 [view my complete system specs]
  • Tue, Apr 25 2006 4:57 PM In reply to
    Idea [I] Re: Sorenson Squeeze Error
    Hi all,
    Sorry, but I omitted to mention that I ensured that the version of Quicktime is 7.0.3.50.
    The version of Squeeze (which is working) is 4.2.301.6.
    Simon
  • Wed, Apr 26 2006 3:05 AM In reply to
    • Edit One
    • Bangkok, Thailand
    • Posts 86
    • Points 1,145
    Well, many thanks to Johnnytex! The tip of manually linking the AIF file worked a treat.
    WRT the comments later in the thread that v5.2.4 is not cleared for Studio use, this is not the case. If you visit the download page for 5.2.4 it clearly states that it is compatable with Studio and I have not encountered any Studio integration issues with it so far (clearly the other bugs remain). The Sorenson issue is, I believe, exactly that and not related to 5.2.4 as I tried going back to 5.2.1 and the problem remained.
    Again thank you all for the input. The forum saves the day again!
  • Wed, Apr 18 2007 12:47 AM In reply to
    • Triny Roe
    • Joined on Thu, Feb 15 2007
    • Posts 5
    • Points 65
    Everything was working fine ... now I keep getting the error message as Sorenson Squeeze encoded the QT ref clips for DVD.
    "The movie file ' " ' cannot be found. Without this file the movie cannot play properly"
    So what is this movie file ' " ' ????  I have no such file.
    At first it did not seem to be a major problem but then I discovered the encoded video files, when I imported them into Avid DVD were a max of approx. 22 min  ... is there a size limit?
    now they wont import at all - message says "unrecognised file". And my last attempt at encoding with Sorenson has led to a shutdown of the software. problem seems to be getting worse and worse as I keep trying.
    I have read previous posts on this error (from last year) - am assuming the fix has been implemented wrt to the Quicktime 7 incompatibility ... we have QT 7.0.2 currently running.
    Are there any other recent upgrades that might cause issues that anyone might know about? Our computer admin persons remotely and automatically update our production computers with all sorts of things despite the fact that I have asked them to check with me first ... :(
    kind regards
    Triny
