Latest post Fri, May 25 2018 3:52 AM by Brian Berdan, ACE. 39 replies.
Page 3 of 3 (40 items) < Previous 1 2 3
  • Mon, Jul 10 2017 6:58 PM In reply to
    • mark.burton
    • London, UK
    • Posts 912
    • Points 11,110
    Re: Record Monitor not updating while trimming in MC 8.5 or 8.5.1
    Its not showing the correct source when a mask or any effect track is being used, so very much still an issue.
    Extend the outgoing shot and we see the incoming shot in the left hand Composer window (and external monitor), not the outgoing shot as we should.
    Trim the outgoing shot and it displays correctly in the Composer window. Turn off the mask track so no effect is in play and it displays correctly when extending.
    So, this is a derivative of the same issue I would say. Whatever is going on, it no longer possible to edit with a mask track or any other effect track enabled I don't think.
    It should be easy to reproduce. We've seen it on all 7 of our systems which are 8.8.4 and 8.8.5. We have tried with the hardware (DNxIO) enabled and disabled - no difference. We have also tried toggling Frame Caching and a load of other settings related to video display, nothing so far has made any difference.
    Let me know if you need a screen capture of the issue.
  • Mon, Jul 10 2017 7:00 PM In reply to
    • Posts 10,204
    • Points 218,070
    Got it Mark.....
    Off to send this to Josh and Alan who worked on the fix.
    Can you send me a screen grab?
  • Sun, Jul 16 2017 6:16 AM In reply to
    • mark.burton
    • London, UK
    • Posts 912
    • Points 11,110
    Is everyone in this thread using DNxIO or other Blackmagic hardware?
  • Sun, Jul 16 2017 7:24 PM In reply to
    Hi Mark,
    It's happening on my laptop too without any hardware attached.
    I also saw that Joe in this thread replied:
    'Ive disconected the Aja box and it still does it.'
    So probably not a hardware related issue.
    Mac Pro late 2013 3,5 Ghz 6-Core, 64Gb, OSX 10.10.5, Avid MC 8.4, Blackmagic Ultrastudio Express Macbook Pro retina 2012 15 inch i7, 16Gb, OSX 10.10.5... [view my complete system specs]
  • Mon, Jul 17 2017 7:12 AM In reply to
    • mark.burton
    • London, UK
    • Posts 912
    • Points 11,110
    Thanks Jasper, sorry I should have spotted that. So its def an Avid software issue then.
  • Wed, Aug 2 2017 7:09 PM In reply to
    I showed this issue to our AVID rep when he came out to give us a tutorial on our upgrade (8.6.5) He said he'd refer it to the bug fixers but I haven't heard anything. This is definitley a problem that needs to be fixed ASAP.
  • Fri, Apr 20 2018 8:11 AM In reply to
    I've just started another project and I see there's been no updates.  Any word on a patch?
    Thx,
    Scott
  • Fri, Apr 20 2018 8:14 AM In reply to
    • mark.burton
    • London, UK
    • Posts 912
    • Points 11,110
    This is fixed. Think it was 8.9.4, can't really remember, but its fine now.
  • Fri, Apr 20 2018 8:51 AM In reply to
    Yes, I can also confirm it's fixed now. Although it doesn't display the mask while trimming, but I think it never did.
  • Fri, May 25 2018 3:52 AM In reply to
    • Brian Berdan, ACE
    • Joined on Mon, Nov 4 2013
    • Usually Seattle or Los Angeles
    • Posts 74
    • Points 795
    This is still a problem for me, with a matte on an upper channel- no updating. I'm on 2018.5.0 on a 2017 MacBook Pro/HighSierra, and this is without any hardware (and with an AJA IO XT as well).  Can't work this way.  Render on the fly is on.
    2017 MacBook Pro High Sierra 10.13.6 MC 2018.12.1 [view my complete system specs]
