Latest post Thu, Feb 8 2018 12:46 PM by Jo. 6 replies.
Page 1 of 1 (7 items)
  • Fri, Mar 4 2016 3:56 PM
    • WYTCAT
    • Joined on Mon, Dec 7 2009
    • Germany
    • Posts 16
    • Points 230
    XDCAM MXF OP1a - Export: Assertion failed Error
    When exporting a sequence as XDCAM MXF OP1a (HD 50Mbits) I often get an Assertion Failed Error and cannot finish the export.
    Assertion failed: m_prevGOP->m_firstFrame == 0, file /Snapshots/relengyosemite2_1453950459/coresw/ImportExport/src/MpegExport/MPEGSampleCache.cpp, line 197
    Project is 1080i50, all used media are freshly ingested (consolidated) XDCAM-HD-422 (Sony) clips and some transcoded files (DNxHD120). Exporting small bits of the timeline for example three edits, only the XDCAM files can invoke the error. Must have something to do with MPEG gop structure ordering during export computation. Workaround for now is doing a video mixdown and then export. That is as always a rock solid workflow but takes extra time we have to avoid for tight daily deadlines... My beloved Console (CMD+6) also quarried an        ExportFileToXDCAM returns false because of [bad VBV level] exception        Thank you for helpful hints!
    ISIS 5000 • 2x MC 8.7.0, DNxIO, iMac Retina 5K 27" 4.0 Ghz i7 Quad core Late 2015, 32GB, MX395X, OS X 10.11.6 •MC 8.7.0, NitrisDX, MacPro • MC 8.7... [view my complete system specs]
  • Thu, Mar 10 2016 5:43 PM In reply to
    • RalphC
    • Joined on Wed, Sep 2 2015
    • Posts 1,833
    • Points 20,230
    • Avid Customer Advocate
      Avid Customer Service
      Avid Employee
    Re: XDCAM MXF OP1a - Export: Assertion failed Error
    Hello WYTCAT,
    We just released  Avid Media Composer 8.5.1.
    Can you please update and let us know if the problem is fixed?
    Regards,
    Ralph
  • Mon, Mar 14 2016 5:23 PM In reply to
    • TrekGate
    • Joined on Tue, Oct 2 2012
    • Posts 8
    • Points 105
    Hello Everyone!
    We also ran into the same error message/problem on Windows with MC 8.5. It turned out the cause of the error message was a rendered effect file on the timeline, because after we cleared the suspicious render file the export of the sequence completed without any errors. It this an 8.5 related problem? Is it fixed in 8.5.1?
    I really like to know before we do an update to system, because we are currently in project and this issue only happened once apart from that we are running stable.
  • Wed, Mar 16 2016 9:46 AM In reply to
    • WYTCAT
    • Germany
    • Posts 16
    • Points 230
    Hello TrekGate,
    After installing 8.5.1 we didn't run into this error again. You should consider an update after you finished your project ;-)
    Thank you AVID support team for your fast reaction and dedicated care!
  • Wed, Mar 16 2016 11:53 AM In reply to
    • TrekGate
    • Posts 8
    • Points 105
    Dear WYTCAT Thanks for the update on the problem. I will schedule the software update ASAP.
  • Sat, Mar 26 2016 2:45 PM In reply to
    • RalphC
    • Posts 1,833
    • Points 20,230
      Avid Employee
    WYTCAT:
    Hello TrekGate,
    Very happy that you are up and running Yes
    Regards,
    Ralph
  • Thu, Feb 8 2018 12:46 PM In reply to
    • Jo
    • Joined on Thu, Feb 8 2018
    • Munich
    • Posts 1
    • Points 5
    Re: XDCAM MXF OP1a - Export: Assertion failed Error Avid
    Hello I'm running into the same kind of error - SYS: Mac Pro 2010 on SSD (I know its old but usually runs superb:-)
    - OS Sierra - 4Core 2.4 GHz - 24GB ram - esata external dive 124MB/s (blackmagic speed test) -
    Avid Subsription, latest Version - all plugins installed and up to date -
    Protools 11 also running on system (fine) just in case this might cause trouble
    Logfile tells in line 372:
    20180206130317 Hardware   DeckLink Mini Monitor 4K
    20180206130340 Ready      Application ready for user
    20180206131044 FatalExcpt Not enough adjacent material to
    create transition.  18.1.0.47600.0
    20180206143510 FatalExcpt Not enough adjacent material to
    20180206175716 Exiting    Application about to exit normally
    20180206175717 Shutdown   Application is terminating normally
    20180207155129 Startup    Avid Media Composer Intel 64-bit(R) 18.1.0 Copyright 2003-2018 by Avid Technology, Inc. 47600
    I'd really be glad if someone could tell me what went wrong - Thankyou!
    Modellname: Mac ProMac OS Sierra Prozessortyp: Quad-Core Intel Xeon Prozessorgeschwindigkeit: 2,4 GHz Anzahl der Prozessoren: 2 Gesamtanzahl der Kerne... [view my complete system specs]
