Latest post Fri, May 11 2018 4:29 PM by Marianna. 22 replies.
Page 1 of 2 (23 items) 1 2 Next >
  • Mon, Feb 22 2016 4:25 PM
    • Francesco
    • Joined on Tue, Mar 11 2014
    • Rome
    • Posts 11
    • Points 135
    OS ERROR
    Hi! Since I've installed WIN 10 PRO on my PC, I received "OS ERROR" on launch my MC (version 8.5)! Every day! I've followed these tips (http://avid.force.com/pkb/articles/en_US/Error_Message/en364211), but nothing changed! I have to close the application and restart PC. What can I do to solve it definitely?? Thanks to all!
    AVID MEDIA COMPOSER 8.5 NITRIS DX, WORKSTATION HP Z400, WIN10 PRO 64, INTEL XEON W3550 3.07 GHz, 6 GB RAM, NVIDIA QUADRO FX3800 [view my complete system specs]
  • Tue, Feb 23 2016 2:02 PM In reply to
    • Posts 9,181
    • Points 205,130
    Re: OS ERROR
    Francesco
    Does it provide an error # after the OS error?  if so what it the complete error message?
    AOL IM:  avidmarianna
    Skype: mariannamontague
  • Tue, Feb 23 2016 3:12 PM In reply to
    • Francesco
    • Rome
    • Posts 11
    • Points 135
    Re: OS ERROR
    Thanks, Marianna! The error comes during the "inizialiting hardware" process on launch Media Composer. I attach a screenshot.Thanks
    [View:http://community.avid.com/themes/avid/utility/ invia immagini]
  • Tue, Feb 23 2016 7:49 PM In reply to
    • Posts 9,181
    • Points 205,130
    Re: OS ERROR
    Franseco
    Did you have any older versions of MC on this system prior to 8.5?   If you did, then remove Avid  with the Media Composer installer.  Delete any remaining Avid folders and files (like extensions you can find).   In the case where an older version use to be installed, there were 2 Media Composer folders present and that was the issue. Reboot the computer. Run the disk utility and fix disk permissions. Install Media Composer again.
    If that is NOT it, what happens if you remove the Ntirs and its driver and try as a software only Win 10 system?
    Report back?
  • Tue, Feb 23 2016 8:38 PM In reply to
    • Francesco
    • Rome
    • Posts 11
    • Points 135
    Re: OS ERROR
    Thanks Marianna,
    no previous version of MC, I use to remove it before installing the new release. I think the problem is NITRIS, I remove the hardware and its drivers, and MC starts normally. But now I don't know how to re-install Nitris' driver! I thought it would be automatic!
  • Tue, Feb 23 2016 9:11 PM In reply to
    • Posts 9,181
    • Points 205,130
    Re: OS ERROR
    what driver version did you have installed for the Nirtis DX
    arianna
  • Wed, Feb 24 2016 8:18 AM In reply to
    • Francesco
    • Rome
    • Posts 11
    • Points 135
    Re: OS ERROR
    Marianna, u're so kind! But...Iìve no idea what driver version was!
  • Thu, Feb 25 2016 1:51 AM In reply to
    • bastian
    • Joined on Fri, Jan 20 2006
    • Brisbane, Australia
    • Posts 67
    • Points 845
    Re: OS ERROR
    I've had the exact same error message happening for a few years now, always from a cold startup, mostly on one machine (Avid 2 in my system specs), and I'm still getting it even though I've upgraded to Win 10 and MC 8.5...
    The only way I ever found to deal with it is just do a restart...
    Avid 1 - Lenovo D30 & Nitris DX, Win 10 Pro, MC 8.9, Asus GeForce GTX 1050Ti, 32gig ram, Proavio EB800MS 16TB array & LSI MegaRaid HBA :: Avid... [view my complete system specs]
  • Thu, Feb 25 2016 9:20 AM In reply to
    • Francesco
    • Rome
    • Posts 11
    • Points 135
    Re: OS ERROR
    Hi Marianna, I removed MC and reinstalled it...now Win identifies Nitris DX! I'm cheking if it will work normally at launch...I'll let u know. Thanks. Francesco
  • Thu, Feb 25 2016 9:22 AM In reply to
    • Francesco
    • Rome
    • Posts 11
    • Points 135
    Re: OS ERROR
    Hi Bastian...it's the same issue happened to me! This morning I tried to remove Nitris and its driver and Media Composer too. I re-installed all! I'll let u know if it works!
  • Wed, May 4 2016 7:24 AM In reply to
    • zonik
    • Joined on Sat, Jan 15 2011
    • Posts 26
    • Points 425
    Re: OS ERROR
    Hi, I got the same issue here, after fresh install of windows 10.
    My workaround is to go to device manager. Then first deactivate mojo dx and then reactivate it. No reboot is necessary and the os error is gone for this session.
    Media Composer 8.8 Windows 10 Pro [view my complete system specs]
  • Wed, May 4 2016 11:23 PM In reply to
    • jkedit
    • Joined on Thu, Nov 17 2011
    • Bratislava - Slovakia
    • Posts 9
    • Points 115
    Re: OS ERROR
    Hi Zonik.
    Glad to hear somebody has figured a workaround how to solve it.
    Having this issue for years on win 7,8 even on qualified workstations Nitris, Mojo doesnt matter.
    Thanks. J
    15x Newscutter 5.5.3.6 SW and DNA on HPxw8400 and Z420, 5x Newscutter 6.0.3.4 SW and AJA IO Exp. on Z420, Avid Isis 100TB with Interplay and PLayout server... [view my complete system specs]
  • Mon, Aug 22 2016 3:00 PM In reply to
    • yoruba
    • Joined on Wed, Jun 15 2016
    • Posts 4
    • Points 80
    Re: OS ERROR
    Disable and enable the device works only temporary.
    I had the same problem with Windows 10 and Media Composer 8.6.1.
    Uninstall the Nitris driver and install again the driver.
    And may be this was the solution.
    Power Options >Choose what the power button do > Turn on fast start-up "Disable!!!" this option
  • Mon, Aug 22 2016 6:16 PM In reply to
    • Lukas Boeck
    • Joined on Fri, Jul 31 2015
    • Austria
    • Posts 413
    • Points 4,820
    Re: OS ERROR
    I've seen this too on a client's machine
    using MC 6.5
    happens about monthly since microsoft's forced upgrade win 7 to 10. (close GWX means install update? oh, how much i hate 'em)
    I'm using the deactivate, reactivate trick in device manager.
    MC 8.4.4 Cusom bulid Supermicro X9SRL-F, 32 Gig Ram, 3ware 9750 6x6TB Seagate EC Drives, LSI 9207 + LTO-6, Mojo DX, Artist Color, Flanders CM240, GTX 1070... [view my complete system specs]
  • Tue, Aug 23 2016 10:15 AM In reply to
    • Francesco
    • Rome
    • Posts 11
    • Points 135
    Re: OS ERROR
    THANKS YORUBA!!! Now it works fine!
