Latest post Thu, Feb 11 2016 7:19 PM by Marianna. 12 replies.
Page 1 of 1 (13 items)
  • Tue, Feb 9 2016 9:00 PM In reply to
    • Terry Hopkins
    • Joined on Thu, Sep 30 2010
    • Charlotte, NC
    • Posts 87
    • Points 1,455
    Avid FX
    Hello,
    I'm currently using Media Composer v8.5. One of my version of Media Composer I had Avid FX (which I believe was a Boris product), but now I don't see Avid FX in the FX tab between the Setting and Format tab. Did I loose or giveup my Avid FX when I upgraded to a newer version of Media Composer?
    Terry
    Intel i7, 12GB ram, Dual 23' monitors, Avid Media Composer 8.4 [view my complete system specs]
  • Tue, Feb 9 2016 10:50 PM In reply to
    • DStone
    • Massachusetts
    • Posts 3,273
    • Points 42,305
    Re: Avid FX
    Have you tried re-installing AvidFX? Also which version of AvidFX do yo have?
    DIY quad core I7-4790K, 16Gb, NVidia GTX 970 4GB, Win 10 Pro, MC 8.7, MC 7.x [view my complete system specs]
    Dave S.
  • Wed, Feb 10 2016 1:02 AM In reply to
    • Terry Hopkins
    • Charlotte, NC
    • Posts 87
    • Points 1,455
    Re: Avid FX
    Hello Dave,
    Looks like I have Avid FX 5.8. I think i installed it in 2010.
    Terry
  • Wed, Feb 10 2016 1:36 AM In reply to
    Re: Avid FX
    Terry Hopkins:
    I have Avid FX 5.8.
    It may be advisable to look at an upgrade to Red 5.5. Works just like Avid FX and can also be run as standalone.  If it is of interest I would ask a questions about your current predicament in the Complete your Suite forum here. Folk from BorisFX keep an eye on that forum. They offer upgrade options from Avid FX and the last couple I times I looked there they also offered a free upgrade to Red 6 when it is released.
  • Wed, Feb 10 2016 2:41 AM In reply to
    • smyers63
    • Joined on Thu, Feb 16 2006
    • Dallas, Texas
    • Posts 3,770
    • Points 44,475
    • Moderator: MCA PC
    Re: Avid FX
    There are several releases from 5.8.2 to 6.4 in the download center.  I fairly sure all you need is a serial number for the version you want to run.
    As far as I know, it still works (with the proper version, probably has to be 64-bit) with MC 8+ but I haven't tried it personally.
    Scott
  • Wed, Feb 10 2016 3:23 AM In reply to
    Re: Avid FX
    smyers63:
    My previous advice to post in the Complete your Suite forum would still be the best place to establish which version (if any) will work reliably with your version of MC. Along with the resources to know whether you serial number will work with it.
  • Wed, Feb 10 2016 3:45 AM In reply to
    • smyers63
    • Dallas, Texas
    • Posts 3,770
    • Points 44,475
    • Moderator: MCA PC
    Re: Avid FX
    AndrewAction:
    smyers63:
    I didn't disagree.  Knowing where to find installers is pretty important to know, too.
    Scott
  • Wed, Feb 10 2016 7:16 PM
    • Terry Hopkins
    • Charlotte, NC
    • Posts 87
    • Points 1,455
    Avid FX
    It was sugested that I post here in this forum. I'm currently using Media Composr 8.5 and I've noticed that I don't see Avid FX in the FX tab. Not sure which version of Media Composer it came with, but I believe I have Avid FX 5.8.
    Should'nt I still be able to use Avid FX (which I believe is a Boris product) with my current version of Media Composer?
    Terry
  • Wed, Feb 10 2016 10:12 PM In reply to
    • BarkinMadd
    • Ontario, Canada
    • Posts 4,509
    • Points 58,930
    Re: Avid FX
    Hi Terry - I'm not sure but I thought Avid FX 5.8 was a 32-bit app which means that it won't work with MC 6.x through 8.5 (which are now 64-bit apps). I could be wrong but this might explain why you don't see Avid FX.
    You might consider $299 for Boris RED which will give you all that Avid FX had plus it now has RT filters (green dot) which previous versions of RED (aka Avid FX) did not have.
    Hopefully someone else here will confirm whether Avid FX 5.8 is 32-bit...
    Camera(s) PXW-X70, HDR-FX1, Hero 3+ | MC 8.10 | QT 7.7.9 | BCC 11 | Sapphire 11 | Mocha Pro 5.5.2 | Titler Pro 6 | Windows 10 Pro x64 | System: P6X58D... [view my complete system specs]
    Steve
    ______________________
    www.nelliedogstudios.com
  • Thu, Feb 11 2016 6:25 PM In reply to
    • Posts 8,802
    • Points 200,380
    Re: Avid FX
    Spot on Barkin.....
    Later reease of FX was 64 bit....
    I would go with Barkins suggestion for the $299 as it is the latest and has stuff FX didnt have.
    AOL IM:  avidmarianna
    Skype: mariannamontague
  • Thu, Feb 11 2016 6:40 PM In reply to
    • Terry Hopkins
    • Charlotte, NC
    • Posts 87
    • Points 1,455
    Re: Avid FX
    Thanks Steve and Marianna, can you provide a specific link to the Boris RED program.
    Terry
  • Thu, Feb 11 2016 7:03 PM In reply to
    • BarkinMadd
    • Ontario, Canada
    • Posts 4,509
    • Points 58,930
    Re: Avid FX
    Try here.
    You might want to contact Boris to make sure they will honor an upgrade from Avid FX (that's how I purchased RED 5.5)...
    Steve
  • Thu, Feb 11 2016 7:19 PM In reply to
    • Posts 8,802
    • Points 200,380
    Re: Avid FX
    Copy me on the note to Boris .... I might be able to help.
