Latest post Thu, Aug 2 2018 4:51 AM by N Ryan. 9 replies.
Page 1 of 1 (10 items)
  • Mon, Feb 8 2016 10:32 AM
    • frediko
    • Joined on Sat, Sep 27 2008
    • Norway
    • Posts 76
    • Points 995
    Calculator
    Ok, a small request :)
    Opening the calculator in a 25fps project - it shows 30fps non drop as default instead of the projects current framerate... It always has, as long as I can remember :)
    Fredrik
    Mostly hp z420/440 on Media Composer 8.x and Symphony 8.x Also Dell Precision m3800 | Win 10 | 16GB memory | Quadro k1100 [view my complete system specs]
  • Thu, Feb 11 2016 2:18 PM In reply to
    Re: Calculator
    Hi Fredrik,
    do you have the latest version of MC, i.e. 8.5? I guess that from version 8.2 the calculator works fine (when I open 25p project the calculator has 25 fps).
    Michal
    Media Composer 8.3, Avid FX 6, BCC 6, Baselight for Avid, Windows7 64-bit [view my complete system specs]
  • Thu, Feb 11 2016 2:37 PM In reply to
    Re: Calculator
    I just tried opening the calculator on 8.5 in a 1080i/50 project, and the calculator opened at 30 non-drop.
    Media Composer 2018.11 w/Symphony/SS/PF options, HP Envy 17t-j100 Quad Edition laptop, Windows 10 Pro, Intel Core i7 2.4GHz, 16 GB RAM, nVidia GeForce... [view my complete system specs]
  • Thu, Feb 11 2016 7:30 PM In reply to
    Re: Calculator
    On 8.5 here with PAL 25i, 25P, 1080 50i and 1080 25P projects here the calculator opens in all of them at 30 non drop. (I have not made a new user since MC 6.0 so that may make a difference)
  • Thu, Feb 11 2016 7:43 PM In reply to
    Re: Calculator
    AndrewAction:
    I just tried opening a 50i project with a brand new user and the calculator opened in 30 non-drop, so I don't think that's it.
  • Fri, Feb 12 2016 8:53 AM In reply to
    • frediko
    • Norway
    • Posts 76
    • Points 995
    Re: Calculator
    So, don't put this one on high priority guys - more a "buggin' me" than actual bug ;)
    Just had to point it out.
  • Mon, Feb 15 2016 11:06 AM In reply to
    Re: Calculator
    frediko:
    I don't know anything about programming, but it seems like it should be relatively easy to have the calculator open up at the same frame rate as the project. (Of course in real life it's probably one of those things that would break something important, like the ability to play back video.)
    Either way, this is the sort of change that would make Media Composer seem like a "smarter" application to me. It doesn't make sense that the calculator doesn't know what the project frame rate is.
  • Tue, Feb 16 2016 3:10 AM In reply to
    • jwrl
    • Melbourne, Australia
    • Posts 8,373
    • Points 96,875
    Re: Calculator
    First, let me say that I totally agree with all of the above.  I suspect that the reason such an obvious thing hasn't been done is that it's in a block of code written a long time ago, and no provision was ever made for it.  The person who wrote the code didn't comment it, and has long ago left Avid.  And so on...
    But it really would be nice if someone could address it!!!
  • Sat, Apr 16 2016 7:39 PM In reply to
    • Kingsride
    • Joined on Wed, Apr 10 2013
    • Posts 68
    • Points 790
    Re: Calculator
    Me too...
    ALWAYS a 30fps calculator when I'm in a 50i project.
    MC 8.4
    Perry
    Macbook Pro Retina | 750GB | 10.10.5 | MC 8.4.2 | Symphony Option [view my complete system specs]
  • Thu, Aug 2 2018 4:51 AM In reply to
    • N Ryan
    • Joined on Thu, Jul 3 2014
    • Posts 82
    • Points 1,000
    Re: Calculator
    I'm currently on MC 8.6.5
    I have the old situation where the Calculator always opens as 30fps no matter the Project Format.
    HOWEVER I discovered a way that makes this work as people have requested; If I open the Calculator and change it to 25fps AND leave it open, then when I shutdown Composer and reopen it (a complete Quit, not just change Projects) then the Calculator will be open on starup and be set to 25fps!
    Seems that somewhere along the line, MC is able to remember the frame rate setting of the Calculator window. It would be great to find that bit of code and build it into either a Setting or the MC State...
    OS 10.11.4 Mac Pro Media Composer 8.6.3 with Symphony & Interplay 3.4 AvidFX 6.4 Neat Video 4.1.4 ISIS5500 [view my complete system specs]
    Neil.
