Latest post Wed, Jan 20 2016 8:39 AM by KaH. 3 replies.
  • Tue, Jan 12 2016 1:27 PM
    • KaH
    • Joined on Tue, Oct 2 2012
    • Posts 20
    • Points 220
    AMT and configured duration limit
    importing large mxf files into Interplay/ISIS using AMT gives the following AMT error:
    [sources\CORE\GHWriter.cpp:1530] Could not write frame as configured duration limit (216000 frames) was reached.
    Could I retrieve the configured limit via AMT, WebService or any other Interplay API in order to handle this case in my software before I hit this limit?
    Regards,
    Kai
  • Tue, Jan 19 2016 2:14 PM In reply to
    • KaH
    • Posts 20
    • Points 220
    Re: AMT and configured duration limit
    Hi again,
    is it possible at all to configure the duration limit? Or is it fixed and we have to split the file?
    Any help is appreciated.
    Kai
  • Tue, Jan 19 2016 4:03 PM In reply to
    • robg
    • Tewksbury, MA
    • Posts 494
    • Points 5,605
    • Avid Developer Moderator
      Avid Employee
    Kai,
    You can specify the maximum duration in the AmtMediaAttributes section in the XML file.
    Here is the comment in the AMT.xsd:
    <!-- In Edit-While-Capture creation of variable size per frame media (e.g. Long-GOP MPEG-2 or SMPTE ST 436 ANC data packets), this value specifies the maximum media duration that can be recoded as a count of frames. -->
    <xs:element name="maxDuration" type="xs:unsignedInt"/>
    You can see an example in XDCAM-HD_50mbps_1080i_60_8A_24bits_DROP_4_hour_max.XML:
    <AmtMediaAttributes>
    <maxDuration>431568</maxDuration>
    </AmtMediaAttributes>
    Also, please see this tech note on maximum clip lengths for Media Composer:
      http://avid.force.com/pkb/articles/en_US/troubleshooting/Maximum-Clip-Length
    Hope this helps,
    - Rob
  • Wed, Jan 20 2016 8:39 AM In reply to
    • KaH
    • Posts 20
    • Points 220
