Latest post Wed, Jul 6 2016 11:23 AM by Jens Hoppe. 10 replies.
Page 1 of 1 (11 items)
  • Sat, Nov 28 2015 4:02 PM
    • MagnusMeerkat
    • Joined on Tue, Nov 29 2005
    • Newcastle Upon Tyne, UK
    • Posts 189
    • Points 2,235
    audio punch in tool strangeness
    After many hours of pulling my hair out wondering why sometimes the punch in tool worked and sometimes it didnt.. I happened upon the answer.  When my digibeta deck is switched on and sending an image into the SDI A IN - the puch in tool works (set to analog xlr).  When I switch the deck off, I get no audio in..
    Strange and very annoying!  Presumable someting to do with genlock?  I'm also unable to capture video from my digi deck as i get the 'No Valid Video Signal' - perhaps a linked issue?
    Avid is this something you're looking into?
    Magnus
    Symphony 2018.5, Mac Pro 2010 3.33ghz 6core, 32gb, OS X 10.11.6, DNxIO --- MC 9.3 Mac Pro 2009 2.6GHz 6 Core, 32GB, OS X 10.11.6, Nitris DX ---- MC 9.5... [view my complete system specs]
  • Tue, Dec 22 2015 1:56 PM In reply to
    • MagnusMeerkat
    • Posts 189
    • Points 2,235
    Re: audio punch in tool strangeness
    if anyone else is wondering about this.  It still doesn't work on 8.4.4 UNLESS you have an input signal going into the dnxio.  I've hooked up a black+burst into my composite PAL in.  Punch-in tool now works as normal.
  • Tue, Mar 8 2016 2:33 PM In reply to
    • WYTCAT
    • Joined on Mon, Dec 7 2009
    • Germany
    • Posts 16
    • Points 230
    Unfortunately it still doesn't work even on 8.5 unless you have connected a video input signal which is the same standard as the project. That's annoying when you often have to switch between HD and SD or progressive and interlaced projects...
    ISIS 5000 • 2x MC 8.7.0, DNxIO, iMac Retina 5K 27" 4.0 Ghz i7 Quad core Late 2015, 32GB, MX395X, OS X 10.11.6 •MC 8.7.0, NitrisDX, MacPro • MC 8.7... [view my complete system specs]
  • Tue, Mar 8 2016 3:46 PM In reply to
    • SchnittKontor_HH
    • Joined on Thu, Mar 30 2006
    • Europe - Germany - Hamburg
    • Posts 92
    • Points 1,050
    Is the front Mic-XLR working for you? Or do you use the four analog inputs with an external Mixer?
    I can`t get the Front-Mic-In to work.
    MC /w. Sym 2018.12.2 | AVID Artist | DNxIO | HP Z820 GEN 2, 2x Xeon E5-2695W v2 12-Core 2.4 GHz, 64GB RAM, GPU: 2x RTX 2080 TI, HP Thunderbolt 2 | Win... [view my complete system specs]
  • Tue, Mar 8 2016 4:30 PM In reply to
    • WYTCAT
    • Germany
    • Posts 16
    • Points 230
    Normally I use the 4 analog inputs with an external mixer, "classic 4-track broadcast style".
    I just tested with a microphone connected to the front input, and doing an audio punch-in – no problem. In the "Blackmagic Desktop Video Utility" you have to select "Microphone" as the audio input. With a good cable Smile and phantom power selected (if needed) it should work.
    Hope that helps!
  • Wed, Mar 9 2016 10:44 AM In reply to
    • SchnittKontor_HH
    • Posts 92
    • Points 1,050
    When you record with the Front-XLR, do you use CH1 in the Audio Punch-In Tool???
    I always get this error: Exception: StreamingPlayConsumer::ExecutePass TIMEOUT
  • Wed, Mar 9 2016 11:44 AM In reply to
    • WYTCAT
    • Germany
    • Posts 16
    • Points 230
    Hi Schnittkontor_HH,
    In the Audio Punch-In tool I used input channels 1 and 2 and the Mic signal was present on both channels.
    I assume you witness the same problem I have - there has to be a video signal connected to the (SDI) video input AND this video signal must be the same format as the Avid project e.g. Project is FullHD 1080/25p the input signal also has to be a FullHD 1080/25p. In this example HD with 50i won't work (workaround could be changing the project settings to your available input signal). Or as Avid suggests somewhere, shortcut SDI-In with SDI-Out (which i find stupid but also works...). With nothing connected I also get the "...StreamingPlayConsumer...TIMEOUT...".
    Hope that helps!
  • Wed, Mar 9 2016 3:35 PM In reply to
    Hi All,
    This is a known issue (that you must feed in video for audio punch-in to work), and we are working with Blackmagic Design to resolve it in a future release.
    Jeremy
  • Wed, Mar 9 2016 5:06 PM In reply to
    • SchnittKontor_HH
    • Posts 92
    • Points 1,050
    Thank you very much, now I get it to work.
    IdeaYesBig Smile
  • Thu, Mar 10 2016 9:39 AM In reply to
    • WYTCAT
    • Germany
    • Posts 16
    • Points 230
    Thank you Jeremy and developers!
  • Wed, Jul 6 2016 11:23 AM In reply to
    • Jens Hoppe
    • Joined on Thu, Apr 21 2011
    • Frankfurt, Germany
    • Posts 64
    • Points 755
    looks like connecting a video source is no longer required. New in MC 8.6.0 with BMD desktop video 10.7.0.
    Jens
    MacPro, MBP, Z400, Z420, Z820, MN5, ISIS5000, Interplay... [view my complete system specs]
