Latest post Tue, Apr 3 2018 12:32 AM by vic7fm. 9 replies.
Page 1 of 1 (10 items)
  • Tue, Nov 3 2015 6:30 PM
    • janusz
    • Paris
    • Posts 394
    • Points 4,535
    Recovering Quicklook for DNxHD on OS X 10.9-10.10
    Posting a little tip that corrects a little annoyance with Mavericks and Yosemite.  It is no longer possible to preview DNxHD Quicktimes (and all other QTs in codecs other than Prores ou H264) with the space-bar.
    It turns out that the old behaviour can be recovered by "transplanting" the quicklook components that handle quicktime files from a copy of OS X 10.8.5.  It works fine - although you need to redo the steps when you update the OS, and you need access to a machine with 10.8.5 to grab the files.
    On a machine with Mountain Lion installed take a copy of the following two files/directories:
    /System/Library/QuickLook/Movie.qlgenerator
    /System/Library/Frameworks/Quartz.framework/Frameworks/QuickLookUI.framework/PlugIns/Movie.qldisplay
    Put them safe somewhere (Avoid FAT32 formatted USB keys as permissions may be lost - zip them if in doubt)
    On the machine with Mavericks/Yosemite, take a copy of the existing files/directories in these locations and replace them with those copied from 10.8.5.  Be careful to only replace these files (not any part of the directories that contain them - doing so will create major headaches)
    Run the following commands from the Terminal to repair permissions (you need to have a password set on the account):
    sudo chmod -R a+x /System/Library/QuickLook/Movie.qlgenerator
    sudo chmod -R a+x /System/Library/Frameworks/Quartz.framework/Frameworks/QuickLookUI.framework/PlugIns/Movie.qldisplay
    sudo chown root /System/Library/QuickLook/Movie.qlgenerator
    sudo chown root /System/Library/Frameworks/Quartz.framework/Frameworks/QuickLookUI.framework/PlugIns/Movie.qldisplay
    Enter your password when prompted (nothing will appear this is normal)
    Reboot.
    The Space bar will now preview DNxHD files and QT reference files as before.
    This should also work with El Capitan, but you will probably need to deactivate System Integrity Protection to replace the files (boot in Recovery mode (Cmd+R on startup), Launch Terminal and type csrutil disable), reboot, replace the files then you can probably reenable System Integrity Protection (csrutil enable in recovery mode) - I have not tested this.
    Janusz
    MC 2018.12 / OS 10.12.6 + others elsewhere [view my complete system specs]
    Filed under: ,
  • Tue, Nov 3 2015 7:01 PM In reply to
    • John Pale
    • Joined on Thu, May 19 2011
    • NYC
    • Posts 155
    • Points 2,075
    Re: Recovering Quicklook for DNxHD on OS X 10.9-10.10
    Cool tip.
    Note that the feature was removed as a security measure.  Third party codecs can cause malicious code to be inserted into QuickTime movies.  Using QuickLook to preview can allow allow that malicious code to be executed even without the file being opened.  This is also why third party codecs are not supported in QuickTime X anymore.  Apple only supports codecs they supply in QuickTime X.  You'll see any file encoded in an unapproved codec will be automatically transcoded when you attempt to open it in QuickTime X.
    there needs to be a simpler override for Pro Video Users.
    Mac Pro 5,1 (2009-firmware upgrade to 2010). Self upgraded to 12 core (2 x Hex Core Westmere 2.93Ghz) 32 GB Ram Mac OSX 10.11.3 Avid MC 8.5 NVIDIA... [view my complete system specs]
  • Mon, Jan 18 2016 4:14 PM In reply to
    THANK YOU THANK YOU THANK YOU !!!!!!!
    3 GHz 8 core Intel Xeon E5 / 32 GB / 10.9.5 / MC8.7.2.44855 / Motu HDX-sdi via PCIe Card / AMD FirePro D300 2048 MB [view my complete system specs]
  • Mon, Feb 22 2016 3:32 PM In reply to
    • ronan
    • Joined on Thu, Jun 10 2010
    • Posts 4
    • Points 40
    Fantastic Tip!!!
    Just successfully used it on El Capitan 10.11.3 using the csrutil disable and enable commands in recovery mode :)
    Thanks a Million!
    HP Z400, Nitris DX 6.0.4 [view my complete system specs]
  • Wed, Feb 24 2016 12:16 AM In reply to
    • Mondo
    • Sydney Australia
    • Posts 1,625
    • Points 18,630
    And for those of us who don't have Mountain Lion installed is it possible to post these two files somewhere? Would be much appreciated.
    John
  • Thu, Jul 14 2016 9:57 PM In reply to
    Mondo:
    Good idea!  Here ya go:
    https://goo.gl/FzWku6
  • Wed, Oct 26 2016 3:54 PM In reply to
    Janusz!  You are my HERO!Yes
    thanky you sooo much for this, no one could help me till now.
    important to put it in the System/library, not the roo/library.   so i had it after my 2nd go at it.
    greatings from Austria
    Michael
  • Wed, Oct 26 2016 9:20 PM In reply to
    • pierreh
    • Paris, London
    • Posts 1,214
    • Points 14,695
    That really made my day, thank you very much!
    A while ago, probably when 10.9 came out, I wondered if doing so would be possible. All Mac "power users" around me said nope. And I gave up and just hated Apple each time I hit spacebar on a DNxHD QuickTime file I came across...
    Never give up on hope!
  • Thu, Nov 3 2016 12:57 AM In reply to
    • Mondo
    • Sydney Australia
    • Posts 1,625
    • Points 18,630
    RobEdits37:
    Thanks - for some reason copying and pasting the chown commands out of the PDF didn't work. It came up asking for correct usage. Copying form Janusz original post worked. Who knows - they look identical and I imagined you just copied hte post..
    John
  • Tue, Apr 3 2018 12:32 AM In reply to
    • vic7fm
    • Joined on Tue, Apr 3 2018
    • Posts 1
    • Points 5
    Wondering if anyone has got this to work on High Sierra properly?  It previews avid quicktimes just fine, but the progress bar isn't visible anymore.  So now I can't scroll through the quicktime.  Appreciate any feedback.
