Latest post Tue, Feb 23 2016 10:58 PM by george777. 5 replies.
Page 1 of 1 (6 items)
  • Fri, Oct 23 2015 12:02 PM
    • george777
    • Joined on Sat, Jul 30 2011
    • Italy, Roma
    • Posts 40
    • Points 565
    playback problem after precomputes cleaning and upgrade
    I’ve upgraded Media Composer from 8.2 to 8.4.2. Everything was fine, so I’ve cleaned the precompute from my project. Since then, my footage has some problems, but only during playback. It is jumpy, stuttering for jumpy. But when I export the footage, everything is fine and the film it's smooth. I have no idea if the problem was generated after the software upgrade or after the pro compute cleaning process, because I upgraded and cleaned the precompute in sequence, and only after that I noticed the problem. What do you suggest?
    Media Composer 2019.9 Mac OS X 10.14.6 Mac Pro late 2013 - Dual 6-Core Xeon E5 3,5 ghz - 32GB 1867 mhz ddr3 ram - Dual AMD FirePro D500 3072 Mb. [view my complete system specs]
  • Sun, Oct 25 2015 2:38 AM In reply to
    • hbrock
    • Santa Monica, CA
    • Posts 5,525
    • Points 64,150
      Moderator: MCA Mac
    Re: playback problem after precomputes cleaning and upgrade
    Try re-rendering your timeline and see if playback improves.  You probaby deleted all the renders and playback could suffer.  You won't see those issues on exports as all everything needs to be rendered before it can be exported.
  • Sun, Oct 25 2015 10:13 AM In reply to
    • george777
    • Italy, Roma
    • Posts 40
    • Points 565
    The timeline is rendered. I'm experiencing some sort of bug. I have been editing on Avid for 10
    years and I have never experienced such a strange behaviour.
  • Sun, Oct 25 2015 5:11 PM In reply to
    • hbrock
    • Santa Monica, CA
    • Posts 5,525
    • Points 64,150
      Moderator: MCA Mac
    What's the format and codec of the affected media?  There was a bug with 6 and 12 core Macs when playing "high resolution" content under Yosemite (OS X 10.10) that recently got fixed.  I wonder if the fix broke something in OS X 10.9?
    Can you revert to 8.2 to see if the problem goes away?  If so, it's a more likely to be reproducible which makes escalation easier.
  • Sun, Oct 25 2015 6:59 PM In reply to
    george777:
    Are you using a third party IO device?  If so,  disconnect it and uninstall the driver and see if playback improves.
    Hope you fix it soon,
    Robert
    2018 MacBook Pro,I7 2.6GHz/32GB RAM/Radeon Pro 560X 4GB/500GB SSD/External RAID0/Mojave & MacPro Early 2009 24GB/GTX1080Ti/1GB SSD/HIT2TB/WD1TB/ProAvio... [view my complete system specs]
    Robert A. Ober
    IT Consultant, Vidcaster, & Freelance Preditor(Producer/Editor)
    www.infohou.com
    Houston, TX
  • Tue, Feb 23 2016 10:58 PM In reply to
    • george777
    • Italy, Roma
    • Posts 40
    • Points 565
    No, I'm not using any third party IO device.
    I'm experiencing the problem only in one project.
