Latest post Wed, Sep 23 2015 12:48 PM by Francesco. 0 replies.
Page 1 of 1 (1 items)
  • Wed, Sep 23 2015 12:48 PM
    • Francesco
    • Joined on Wed, May 16 2012
    • Pisa - Italy
    • Posts 68
    • Points 675
    AMA File Export on network folder
    Hi to all
    attempting to export using "AMA File Export option" when a network folder is selected I experienced the result is in a message "Unable to write" like if the folder is not shared in write mode.  I found that whatever plugin I select, the result is the same. Obviously the directory is shared in write mode.
    Inserting some OutputDebugString in the plugin I saw that if the folder is a local one the MediaVolumeWriter::GetWriterCapabilities is called three times and next is called ContainerWriter::AddAAFClips.  If the destination folder is a network one, I see only one call to MediaVolumeWriter::GetWriterCapabilities and no call to ContainerWriter::AddAAFClips.
    We have a customer that is using MC 8.3.1 (with windows 7 professional) with our plugin.
    I found the same bug on windows 8.1 both  with MC8.3.1  and with MC 8.4.1 (after updating).
    Any suggestion ?
