Latest post Fri, Sep 11 2015 2:50 AM by dmfreeman. 5 replies.
Page 1 of 1 (6 items)
  • Sat, Aug 15 2015 11:26 AM
    • dmfreeman
    • Michigan
    • Posts 1,856
    • Points 24,320
    Uninstall New Blue Titler Pro 3 Before Installing v 4
    Hopefully someone will let me know this.  When I installed NB Titler Pro 4, I already had version 3 installed on my computer.   My assumption was (wrongly) that the new install would uninstall the prior version.  I noticed in Control Panel>Programs and Features, still lists both.  Should v3 be uninstalled, or would this cause issues with v4?
    Denny
    Media Composer 2019.6, BCC Continuum 12.5, , Boris Red 5.6., Asus P9X79 Pro Motherboard with Intel 3930K Processor. 32 gigs DDR3 ram, Windows 10 Pro 1803... [view my complete system specs]
  • Sat, Aug 15 2015 11:33 AM In reply to
    • BarkinMadd
    • Ontario, Canada
    • Posts 4,707
    • Points 61,490
    Re: Uninstall New Blue Titler Pro 3 Before Installing v 4
    Hi Denny - I noticed the same thing (and made the same assumption). I haven't tried uninstalling TP3 so I can't tell you if it will damage your TP4 installation but I suspect that it would. You might have to deactivate and uninstall both and then install TP4 again. Personally, I'm just going to leave it as-is for now.
    Camera(s) PXW-X70, HDR-FX1, Hero 6 Black | MC 2019.9 | QT 7.7.9 | Continuum 2019.5 | Sapphire 2019.5 | Mocha Pro 2019.5 | Titler Pro 7 | Windows 10 Pro... [view my complete system specs]
    Steve
    ______________________
    www.nelliedogstudios.com
  • Sat, Aug 15 2015 12:20 PM In reply to
    • dmfreeman
    • Michigan
    • Posts 1,856
    • Points 24,320
    My thoughts are the same, "If it ain't broke, don't fix it".  Perhaps Marcus from NB might give us some direction on this.
    Denny
  • Thu, Aug 27 2015 1:27 PM In reply to
    dmfreeman:
    Denny
    Hi Denny,
    It's possible you had our original version of Titler Pro 3 installed. Back at the beginning of the year we moved to a unified activation manager for our products, which also changed the installers and update process. So if you had a version of TP3 that was loaded with the old installer, that might be why the Titler Pro 4 installer didnt remove it.
    Anyway as long as it's not causing you any problems I wouldn't worry about it. Out of curiosity are you seeing more than one Titler Pro entry in your effects palette, or just the one for Titler Pro 4?
  • Fri, Aug 28 2015 12:44 AM In reply to
    • dmfreeman
    • Michigan
    • Posts 1,856
    • Points 24,320
    Hi Marcus,
    Titler Pro, and Titler Pro 4 both appear in the effects palate.  When I try to put Titler Pro 3 to the timeline, Media Composer crashes and I go to the desktop.  Would this indicate that I should uninstall TP 3? or just not use it?
    Denny
  • Fri, Sep 11 2015 2:50 AM In reply to
    • dmfreeman
    • Michigan
    • Posts 1,856
    • Points 24,320
    Hi Marcus,
    I see both v3 and v4 in my effects palate.  Trying to load v3 will crash MC.  Should I uninstall v3, and if I do, what will happen to v4?  Will it continue to function properly, or would I have to reinstall it?
    Denny
