Latest post Tue, Apr 4 2017 9:59 AM by Leo. 6 replies.
Page 1 of 1 (7 items)
  • Sun, Aug 9 2015 12:26 PM
    • Florian
    • Germany
    • Posts 332
    • Points 4,140
    Blackmagic Mini Monitor audio output MC 8.4
    Hello,
    i have got a strange Problem here.
    I´ve connected a Blackmagic Mini Monitor via Thunderbolt to my iMac and via HDMI to my Client Monitor, since i´ve done that Audio is gone, I see the meters while adio is playing, but no chance to get the Output back to my speakers (connected to the caldigt ts2)
    FCPX and Resolve 12 play back Audio just fine and provide the Monitor with the accurat picture,
    Why isn´t Avid capable of doing so?
    Any Ideas??
    kind regards
    6TB LaCie 2big, QT X, QT 7.6.6, Squeeze 8.5, BCC 8.2 MacBook Pro Retina 15", 2.5Ghz QuadCore i7, OS Mojave 10.14, Avid MC 2018.5, 16GB Ram, AMD Radeon... [view my complete system specs]
  • Mon, Aug 10 2015 12:41 AM In reply to
    Re: Blackmagic Mini Monitor audio output MC 8.4
    I bought this:
    http://www.amazon.com/Kanex-Pro--Embedder-2-Channel-HAECOAX/dp/B009KAU0WO/ref=sr_1_1?ie=UTF8&qid=1439166823&sr=8-1&keywords=kanex+pro
    to split the audio.  I run optical to my Apollo Twin.  You should watch for sync issues with a setup like this.  I don't notice any but others might.
    Not sure exactly how you are running the speakers from the TS2 but the Kanex has both digital and analog out for audio.
    Hope that helps,
    Robert
    MacBook Pro Late 2013 2.6 ghz I7/16gb RAM/GT 750M/1TB PCIe SSD & MacPro Early 2009 24GB/GTX1080Ti/HIT2TB/WD650/WD1TB/ProAvio Scary RAID External. [view my complete system specs]
    Robert A. Ober
    IT Consultant, Vidcaster, & Freelance Preditor(Producer/Editor)
    www.infohou.com
    Houston, TX
  • Mon, Aug 10 2015 5:33 AM In reply to
    • Florian
    • Germany
    • Posts 332
    • Points 4,140
    Thank you Robert,
    i just ordered an Audio extractor which i have to put between two hdmi cables and plug in the speakers into that little thing.
    hope this will work
    Sad that i have to pay for something what will work with other NLEs for free...
  • Mon, Aug 10 2015 7:35 AM In reply to
    • hbrock
    • Santa Monica, CA
    • Posts 5,520
    • Points 64,055
      Moderator: MCA Mac
    Some HDMI monitors have a analog audio output that will provide a decoded audio signal from the HDMI input and if so, it's likely to be in correct sync.
  • Sat, Apr 1 2017 1:57 AM In reply to
    • Leo
    • Joined on Mon, Feb 14 2011
    • Berlin
    • Posts 38
    • Points 360
    same here.
    my HDMI monitor/TV has analog output, but at a much lower quality than the output on my macbook pro. ill give the mini monitor back :( !
    2017 iMac i7 24GB RAM 8GB Radeon 580. OSX Mojave. 2011 MBP i7 16GB RAM AMD HD 6750M 1GB Video. OSX 10.11.5 Avid MC 8.8.0 [view my complete system specs]
  • Sun, Apr 2 2017 7:46 PM In reply to
    Leo:
    same here.
    Not sure what you are saying but if one wants a standard video output from a computer (especially laptops and trashcan Mac Pros) then one wants something like the Min Monitor or a high priced solution like a DNxIO.
    One cannot rely on the HDMI out on a computer to follow standards.  Also,  an HDMI output on a computer is not likely to be recognized as a VIDEO out as opposed to a MONITOR connection point.
    Y'all have some fun,
    Robert
    Robert A. Ober
    www.infohou.com
    Houston, TX
  • Tue, Apr 4 2017 9:59 AM In reply to
    • Leo
    • Berlin
    • Posts 38
    • Points 360
    Robert A. Ober:
    I did explain wrong. Also my setup is obviously not very professional, other wise wouldnt use the mini monitor but.
    I use a consumer monitor feed by the ultrastudio mini monitor.
    But Avid fails to be able to select 2 different I/O for audio and image.
    It all gets send through the mini monitor, which is frustrating, because there I have no good audio output. Just image/sound through hdmi/sdi.
    I would much rather want to connect my speakers to my laptop and feed the consumer monitor with the ultrastudio mini.
