Latest post Fri, Jun 19 2015 11:46 PM by jwrl. 5 replies.
Page 1 of 1 (6 items)
  • Tue, Jun 16 2015 5:25 PM
    • claubel
    • Joined on Thu, Dec 21 2006
    • Denmark
    • Posts 17
    • Points 225
    Matrox MXO2 mini not detected in MC 8.3
    Hello
    I just made a clean installation of Windows 7 and Media Composer 8.3.1.34700.
    Everything is fine except for my Matrox MXO2 Mini is not detected at all by Media Composer. I also installed the newest Matrox drivers 7.7.2.2018, which should work with MC8.3
    I can use the Matrox control panel just fine, so the hardware is working.
    Any idea?
    Avid MC 8.4.3, HP z800, Windows 7 SP1, 8 GB RAM, Matrox MXO2 Mini v. 7.7.2.2018, QT 7.7.9, Sorenson Squeeze 8. [view my complete system specs]
  • Wed, Jun 17 2015 12:01 PM In reply to
    • dmfreeman
    • Michigan
    • Posts 1,851
    • Points 24,235
    Re: Matrox MXO2 mini not detected in MC 8.3
    I would contact Matrox tech support.  Info can be found at http://www.matrox.com/graphics/en/support/contact/
    Does the monitor connected to the MXO2 have input?  There is an icon on top of the timeline that needs to be clicked on to allow the output to the MXO2 to show up, is it activated?  In Settings have you enabled the MXO2?
    Hope this gives you some direction to resolve the issue.
    Denny
    Media Composer 8.5.4, BCC 10.0.0074, AvidDVD 6.4.4, Boris Red 5.5.2.1382, Asus P9X79 Pro Motherboard with Intel 3930K Processor. 32 gigs DDR3 ram, Windows... [view my complete system specs]
  • Wed, Jun 17 2015 12:17 PM In reply to
    • claubel
    • Denmark
    • Posts 17
    • Points 225
    Thanks, dmfreeman
    There is no MXO2 setting or video output setting available in Avid settings. The Client monitor icon is greyed out.
    It is like Avid does not detect the hardware at all, even though the MXO2 is recognized in Windows.
    Usually the name in the top application border changes to "Avid Media Composer MXO2 Mini", which it does not.
    I tried to contact Avid 24h phone support yesterday, but still after an hour nobody had answered my call :-(
    I will follow your advice and contact Matrox support.
  • Thu, Jun 18 2015 1:58 AM In reply to
    • dmfreeman
    • Michigan
    • Posts 1,851
    • Points 24,235
    Hello Claubel,
    Just above the timeline to the right of the audio meter is a gear shaped icon.  If you hover over it, it should show "HW/SW.  If you click it it should enable the output to the external monitor.  Also, does the external monitor show input from the MXO2?.
    If these issues don't resolve the issue I will stand by my initial idea which is to contact Matrox support.
    Denny
  • Fri, Jun 19 2015 1:50 AM In reply to
    Hi mate,
    Just thought you might find it helpful to know that MX02 mini works fine for monitoring under 8.3.1, even 4K footage (though only at 2K obviously). We have been doing so on two machines for a couple of months.
    Tony
    MC 8.3.1 Windows 7 intel i7 3930k nvidia quadro k4200 32gb ddr corsair ram (4x8gb DIMMs) 128gb Samsung 840 sata3 ssd (system) 4*2tb western digital... [view my complete system specs]
  • Fri, Jun 19 2015 11:46 PM In reply to
    • jwrl
    • Melbourne, Australia
    • Posts 8,387
    • Points 97,025
    Haven't tried 4K, but have tried 2K.  It works for me with my MXO2 mini too.
