Latest post Wed, May 6 2015 2:45 PM by mjolnarn. 4 replies.
  • Wed, May 6 2015 4:09 AM
    NEED HELP - Glitch Installing Avid Media Composer 8
    Hello!  Thank you for any insight you can share....
    I've worked in Avid MC on my laptop for years, and I just inherited a very powerful desktop computer that used to have MC 6.5 installed on it in the past.
    Today, I successfully did a clean-install of Windows 7 Professional 64-bit Service Pack 1 on it in order to load Avid 8.3.1.
    I then downloaded the latest free version of Avid Media Composer 8.3.1 and started the installation process.  All went well until it reached the last item on the list: Avid Application Manager 2.2.
    The system says: "Avid Media Composer is preparing the InstallShield Wizard to help guide you through this process," and then a window pops up with a lot of technical info (listed below), titled "Windows Installer."  It has only ONE option at the bottom: to hit the "OK" button.  When you do that, nothing else happens!  Hitting "OK" closes that "Windows Installer" window and brings you back to the Media Composer menu where it says "Please choose an application to install..." and there is a red "X" next to Media Composer.
    Clicking that Media Composer option to try again opens a dialogue box that says:  "Avid MC requires the following items to be installed on your computer.  Click Install to begin..."  The item listed is Avid Application Manager 2.2.  When I click "Install" it does the same thing again, ending with that "Windows Installer" window where you can only click "OK."   It becomes an endless loop.
    Ironically, when I close all of those windows and click on the START button, it shows that the Avid Application Manager 2.2 WAS installed!  I've opened it and tried using it to install MC.  It leads me into that same endless loop again at the same point (listed above).
    I have scoured the web trying to find how to get the normal InstallShield Wizard to work and to continue the installation....all to no avail.  I'm just stuck in this loop...
    Here is the message that it says inside the "Windows Installer" window:
    ______________
     Windows ® Installer. V 5.0.7601.17514
    msiexec /Option <Required Parameter> [Optional Parameter]
    Install Options
    </package | /i> <Product.msi>
    Installs or configures a product
    /a <Product.msi>
    Administrative install - Installs a product on the network
    /j<u|m> <Product.msi> [/t <Transform List>] [/g <Language ID>]
    Advertises a product - m to all users, u to current user
    </uninstall | /x> <Product.msi | ProductCode>
    Uninstalls the product
    Display Options
    /quiet
    Quiet mode, no user interaction
    /passive
    Unattended mode - progress bar only
    /q[n|b|r|f]
    Sets user interface level
    n - No UI
    b - Basic UI
    r - Reduced UI
    f - Full UI (default)
    /help
    Help information
    Restart Options
    /norestart
    Do not restart after the installation is complete
    /promptrestart
    Prompts the user for restart if necessary
    /forcerestart
    Always restart the computer after installation
    Logging Options
    /l[i|w|e|a|r|u|c|m|o|p|v|x|+|!|*] <LogFile>
    i - Status messages
    w - Nonfatal warnings
    e - All error messages
    a - Start up of actions
    r - Action-specific records
    u - User requests
    c - Initial UI parameters
    m - Out-of-memory or fatal exit information
    o - Out-of-disk-space messages
    p - Terminal properties
    v - Verbose output
    x - Extra debugging information
    + - Append to existing log file
    ! - Flush each line to the log
    * - Log all information, except for v and x options
    /log <LogFile>
    Equivalent of /l* <LogFile>
    Update Options
    /update <Update1.msp>[;Update2.msp]
    Applies update(s)
    /uninstall <PatchCodeGuid>[;Update2.msp] /package <Product.msi | ProductCode>
    Remove update(s) for a product
    Repair Options
    /f[p|e|c|m|s|o|d|a|u|v] <Product.msi | ProductCode>
    Repairs a product
    p - only if file is missing
    o - if file is missing or an older version is installed (default)
    e - if file is missing or an equal or older version is installed
    d - if file is missing or a different version is installed
    c - if file is missing or checksum does not match the calculated value
    a - forces all files to be reinstalled
    u - all required user-specific registry entries (default)
    m - all required computer-specific registry entries (default)
    s - all existing shortcuts (default)
    v - runs from source and recaches local package
    Setting Public Properties
    [PROPERTY=PropertyValue]
    Consult the Windows ® Installer SDK for additional documentation on the
    command line syntax.
    Copyright © Microsoft Corporation. All rights reserved.
    Portions of this software are based in part on the work of the Independent JPEG Group.
    ______________
    I am working on a Cyberpower Thermaltake desktop PC.  Here are the specs:
    Windows 7 Professional 64-bit Service Pack 1 Intel(R) Core(TM) i7-3820 CPU @3.60 GHz RAM: 32 GB
    ------ Thank you SOOOO MUCH for any help you can provide.  Your time and assistance are much appreciated...
    Media Composer v.5.5.1 on my DELL laptop (running Windows 7 Ultimate 64-bit). Shoot on: Canon 5D Mark iii that records .MOV files at 1080/30p in IPB... [view my complete system specs]
  • Wed, May 6 2015 5:48 AM In reply to
    • mjolnarn
    • Joined on Wed, Feb 8 2006
    • Sweden
    • Posts 13,346
    • Points 159,335
    Re: NEED HELP - Glitch Installing Avid Media Composer 8
    App Man should be installed first thing, so before Avid.
    You seem to have used the wrong installer or uncorrect install procedure
    add ..  and I can´t remember having seen this either
    Tomas
  • Wed, May 6 2015 6:53 AM In reply to
    Try uninstalling the Avid Application Manager.  (Control Panel\Programs and Features\ select Avid Application Manager and click on Uninstall)
    Move the downloaded Avid installer ( Media_Composer_8.3.1_Win.zip ) to the root level of your C:\Drive.
    Extract this file  to your C:\drive.
    From the resultant Media_Composer_8.3.1_Win folder use the "Install Media Composer.exe" to install.
    As Tomas says you should then see the Avid Application Manager install as one of the first parts of the process.
  • Wed, May 6 2015 2:26 PM In reply to
    I honestly cannot thank you both enough!!!  It worked!!!  I so appreciate all your help and the time you took to write and help me resolve this issue.  It was getting really frustrating, so thank you for being so kind and helping me out.  It really means a lot to me.
    As soon as I moved the .ZIP folder onto my C: drive and started the whole process again, everything worked.
    Have a great day!!
  • Wed, May 6 2015 2:45 PM In reply to
    • mjolnarn
    • Sweden
    • Posts 13,346
    • Points 159,335
    I found the error and Andrew the fix.
    Happy continued editing Yes
    Tomas
