Latest post Sat, May 26 2018 7:17 PM by kaspar65. 3 replies.
  • Fri, Apr 17 2015 8:32 AM
    • Francesco
    • Joined on Wed, May 16 2012
    • Pisa - Italy
    • Posts 68
    • Points 675
    Error exporting
    Hi
    in these days we are testing our plugin with latest version of MediaComposer (8.3.1).  In exporting material there is an error:
    @ Fri Apr 17 10:27:14 2015
    * Exception: std::exception, what:ACF call failed: sampleConsumer->Setup (trackIndex, 0), error code 0x80000001, file ..\..\src\AMAExport\AMAExportMedia.cpp line 64
    Any suggestion ?
    regards
    Filed under: , ,
  • Tue, Apr 21 2015 10:24 AM In reply to
    • Francesco
    • Pisa - Italy
    • Posts 68
    • Points 675
    Re: Error exporting
    Hi
    I found solution.  The anomaly borns in SampleConsumer::Setup method.  Up to AVID Media Composer 7.5 returning ACF_E_NOTIMPL doesn't create problems.  Seems that whit version greater than 8.3.0 this generate the reported error.  I solved returning  ACF_OK.
    regards
  • Wed, Apr 22 2015 1:12 PM In reply to
    Re: Error exporting
    Hi Francesco,
    Yes, we've seen this happen with several AMA plug-ins that initially only implemented what was immediately necessary, only to be surprised when a new version of the AMA-enabled application (Media Composer, ProTools, Media Director) flagged the unimplemented functions.
    To help prevent this we provide an AMAValidator that exercises your plug-in's AMA interfaces (for AMA linking, sample-provider/sample-mapping, but not yet the AMA export functionality).  I will send you a follow-up email with the details.
    - Don
  • Sat, May 26 2018 7:17 PM In reply to
    • kaspar65
    • Joined on Sun, May 20 2018
    • Posts 2
    • Points 10
    Re: Error exporting
    Hi, i red your post and I was intersted in the solution
    I have same error acf but i cant understand how to fix it
    if you can help i'd appreciate
    thanks
    marcello
