Latest post Wed, Apr 15 2015 12:20 PM by olenad. 3 replies.
  • Mon, Apr 13 2015 10:37 AM
    • giapnt
    • Joined on Sat, Nov 22 2014
    • Posts 5
    • Points 55
    iNEWS API with Java
    Dear,
    In C#, the web service will provide a class called CookieContainer which will store the session after INewsSystem call login, so other services such as INewsQueue can use as followed
    CookieContainer cookieJar = new CookieContainer();
    _svc.CookieContainer = cookieJar;
    _qsvc.CookieContainer = cookieJar;
    However, we don’t have a similar container in Java, so the question is, how do we handle the cookies in this case? After logged in successfully with
    response = _svc.getINEWSSystemPort().connect(connect);
    We try to call setCurrentQueue from INEWSQueue but this prompts error saying we must login first. Could anyone share us some opinions here?
    Best regards,
    Giap
  • Tue, Apr 14 2015 10:16 AM In reply to
    • olenad
    • Joined on Thu, Nov 6 2014
    • Posts 34
    • Points 375
    Re: iNEWS API with Java
    Hi Giap,
    Your question is about difference between C# and Java languages and I am not sure if I can find JAVA expert to help you with the answer.
    I'll be back to you if I will.
    Olena
  • Wed, Apr 15 2015 3:05 AM In reply to
    • giapnt
    • Posts 5
    • Points 55
    Hi Olena,
    Thank you for your attention!
    Looking for the feedback.
    Best regards,
    Giap
  • Wed, Apr 15 2015 12:20 PM In reply to
    • olenad
    • Posts 34
    • Points 375
    Hi Giap,
    I do not have some examples for you since I nobody here has such experience.
    But it is recommended to google for "cookie in HttpComponents" hints since JAVA uses this modules to handle web connections: it has HttpClient, Coockie class etc.
    Hope this helps.
    Olena
