Hello,
I have a problem with playback of 9 split multicam.
The source is linked RroRess 422 1080i, i transcoded to DV PAL 25i. 16 tracks audio also transcoded.
The shots are from 30 seconds to 1 hour long.
The playback is smooth, but freezes every 6-7 secs for 3-4 secs (audio also freezes).
My machine is HP Z400 with Xeon W3520, 24 GB RAM, Quadro 2000. I tested on Z620 with Xeon E5 2609, 32 GB RAM, Quadro 4000 - same problem. The storage is RAID 6 with 12 x 7200 RPM harddisks, 10 GbE/sec connection. Avid Media Composer 6.5.4.5
What happens when you reduce the camera to 6 or 4?
Which 10GbE card do you have installed? Direct or through a switch? In fact, which storage is it?
DQS
www.mpenyc.com
