Latest post Mon, Jun 15 2015 9:52 AM by cazzimir. 1 replies.
Page 1 of 1 (2 items)
  • Wed, Mar 18 2015 8:22 PM
    • Isaac T.
    • Joined on Mon, Jan 9 2006
    • New York / Knoxville, TN
    • Posts 749
    • Points 8,840
    MC 8.3 - Selecting Clip Colors
    Hello Everyone,
    As you may know, Media Composer allows you to designate clip colors. If Clip Color -> Source is enabled in your timeline, you can see at a glance which clips are in use.
    Prior to 8.3, you could [Alt] + click on the color column in a bin, then pick a color. Not so now. [Alt] + click-ing may lock up MC, leading to a Force Quit, which could lead to lost work.
    From Media Composer 8.3.1's Help:
    Here's the thing:
    Bullet 1 works.
    Bullet 2 works.
    Bullet 3 is just plain wrong.
    I started trying key combos. Here's what works:
    1. [Control] + [Command] + click - invokes Avid's color picker.
    2. [Control] + [Option] + click - invokes the OS X's color picker.
    So if you're used to the [Alt] + click, watch out.
    Mid-2010 Mac Pro • 2018 MacBook Pro [view my complete system specs]
    isaact.co | Twitter | Instagram | Vimeo
    Writer: The Frame.io WORKFLOW Guide - http://workflow.frame.io/
    Post Workflow Consultant - https://isaact.co/
  • Mon, Jun 15 2015 9:52 AM In reply to
    • cazzimir
    • Joined on Wed, Feb 25 2015
    • Paris
    • Posts 11
    • Points 165
    Re: MC 8.3 - Selecting Clip Colors
    Hello,
    Try using the console command :
    useCrossPlatformColorPicker 1
    Then the [Alt] + click on the color column in a bin, will work Stick out tongue
    I guess It’s a nasty old bug ,Avid should have a look on that Smile
