Latest post Mon, Mar 12 2018 1:54 PM by PePeGagnon. 6 replies.
Page 1 of 1 (7 items)
  • Tue, Feb 3 2015 10:28 AM
    • Nikolai H
    • Joined on Tue, Nov 27 2012
    • Norway
    • Posts 20
    • Points 265
    Batch import not working; The file name or path cannot be processed correctly.
    I had a few files go offline, and I want to batch import them to make them go online again.
    I have the original files, so I link to them in the batch import tool.
    After the import bar is at 100% the following message appears:
    error message
    (edit: my system language is in UK English, my keyboard settings are in Norwegian. I've had these settings for years without any issue)
    I then get this message:
    error2
    This is the console message: (which is totally different from the first error message)
    console message
    The files are offline, I don't know why it's saying I have the files on my target drive.
    Any way I can force Avid to batch import the files?
    HP Z420 3.60Ghz 16GB RAM. [view my complete system specs]
    Filed under: ,
  • Tue, Feb 3 2015 11:11 AM In reply to
    • mjolnarn
    • Joined on Wed, Feb 8 2006
    • Sweden
    • Posts 13,346
    • Points 159,305
    Re: Batch import not working; The file name or path cannot be processed correctly.
    Nikolai H:
    Hi Nikolai, you are mixing the terms here.
    When you import clips new avid media is created and if you loose that media a batch import will recreate that avid media
    When you ama link no new media is created and if you loose that link in a future you just need to link to that media once again, maybe it have been moved to a new folder or drive.
    So, how was the media originally brought inside your project , was it linked or imported , two totally different kind od workflows
    Tomas
  • Tue, Feb 3 2015 11:26 AM In reply to
    • Nikolai H
    • Norway
    • Posts 20
    • Points 265
    The files in question was imported through an AAF.
    It is all audio files.
    The AAF I imported had the files embedded, but I also have the embedded files as .wavs  - if that makes any sense.
    Which might be the reason the batch import is not working as I want it to.
    I can import the whole sound AAF again, but this won't relink my current clips.
    Any ideas?
    Sorry if this is messy, I'm trying to figure this out myself.
  • Tue, Feb 3 2015 11:36 AM In reply to
    • mjolnarn
    • Sweden
    • Posts 13,346
    • Points 159,305
    Ok, thanks, it seems like that the file that doesn´t want to relink have been moved to another place since the aaf was originally created, maybe those more used to fixing broken aaf workflows will come to your rescue here.
    Tomas
  • Mon, Mar 12 2018 1:25 PM In reply to
    • PePeGagnon
    • Joined on Mon, Aug 27 2012
    • Posts 3
    • Points 35
    Probably somewhere in your path you have a folder with a special character. like * or % or something. That's all.
  • Mon, Mar 12 2018 1:33 PM In reply to
    PePeGagnon:
    While it may be that the OP had special characters in their file path, this thread is 3 years old. Just FYI.
    Media Composer 2018.5 w/Symphony/SS/PF options, HP Envy 17t-j100 Quad Edition laptop, Windows 10 Pro, Intel Core i7 2.4GHz, 16 GB RAM, nVidia GeForce GT... [view my complete system specs]
  • Mon, Mar 12 2018 1:54 PM In reply to
    • PePeGagnon
    • Posts 3
    • Points 35
    So what it's 3 years old. I had to search for that error today and found the answer. So if someone is getting this error they will have an answer. Where I work they still are on windows7, not my setup ;)
    JP
