Latest post Thu, Jan 8 2015 9:52 PM by Dan Rapela. 3 replies.
  • Thu, Jan 8 2015 11:50 AM
    • daktulus
    • Posts 913
    • Points 13,065
    How to import DNxHD mxf?
    MC 7.03
    I have a 1080p25 project and try to import a DNxHD 185 X mxf.
    I put it in a numbered mxf folder, started Avid and got error messages: MXF is not op-Atom.
    The client exported the file from Premiere as DNxHD 185 X.
    I tried to import into a bin - not possible.
    I tried to AMA-link - not possible.
    How do I do this?
    How can I check if the file is broken?
    i7, Nvidia 860M, 16GB RAM, 500GB SSD, MC 7.03. Dell Precision M90, Core2Duo 2.16Ghz, FX1500, SATA 7200rpm, MC 4.05. Dell650, 2.8Ghz, 3 GB RAM, FX500, 5... [view my complete system specs]
  • Thu, Jan 8 2015 1:23 PM In reply to
    • smrpix
    • Joined on Wed, Sep 5 2012
    • Posts 1,347
    • Points 16,570
    Re: How to import DNxHD mxf?
    Premiere outputs OP-1a mxf files which are not the same as Avid's op-atom mxf files, so dropping them into a numbered folder will not work.
    AMA should work.  Sometimes you have to specify the mxf plug-in rather than autodetect.  If that doesn't work, the odds increase it's a broken file.
  • Thu, Jan 8 2015 8:43 PM In reply to
    • daktulus
    • Posts 913
    • Points 13,065
    How do I specify the Plug-in?
    Now I have a XDCAM HD mxf that could be at least be imported. I couldn´t AMA -Link that either.
  • Thu, Jan 8 2015 9:52 PM In reply to
    • Dan Rapela
    • Joined on Tue, Oct 18 2011
    • Washington, DC
    • Posts 21
    • Points 510
    Are your AMA drivers up to date and compatible with version 7.03?  (That was my first thought reading this).  You should be able to specify your AMA codec in a dropdown under auto-detect --- but that might be dependent on the drivers you have installed.
