Latest post Wed, Apr 29 2015 6:52 PM by mjolnarn. 37 replies.
Page 1 of 3 (38 items) 1 2 3 Next >
  • Sat, Dec 27 2014 1:30 PM
    • sasfog
    • Bristol United Kingdom
    • Posts 314
    • Points 3,935
    BCC8 and MC8.3
    Hi
    I've just noticed that all my BCC effects have dissapeared from my effects palet?
    I got it bundled with an earlier release of MC, am I now to beloieve I cannot use it with newer versions of MC unless I pay for the Symphony option?
    Seems a bit of a con if that is the case that I cannot use the full version that I have and have to pay again for the lite version that is included in the Symphony option?
    or am I missing something?
    Graham
    HP Z400 6 Core Intel Xeon W3680 3.33GHz 6GB memory NVIDIA Quadro 2000 1GB PCIe graphics card MC6 [view my complete system specs]
  • Sat, Dec 27 2014 1:37 PM In reply to
    Re: BCC8 and MC8.3
    What version of MC did you upgrade from, and what version of MC did you upgrade to?  If it was MC 5.5 or earlier, that was a 32-bit app, and the BCC plugins were also 32-bit, so they won't work with the newer, 64-bit versions of MC.
    However, you say it's BCC8, which is the 64-bit version, so it should work with MC8.
  • Sat, Dec 27 2014 1:45 PM In reply to
    • sasfog
    • Posts 314
    • Points 3,935
    Re: BCC8 and MC8.3
    Just upgraded from 8.2 to 8.3. I have BCC 8.something but only just noticed its not showing in the effects palet, also noticed its icon has dissapeared off my desktop but it is still shown as an installed program.
    I will re-install it and see if that resolves the issue.
    Graham
  • Sat, Dec 27 2014 2:00 PM In reply to
    Re: BCC8 and MC8.3
    Yeah, that's weird.  If it was present and working in 8.2, it should still be present and working in 8.3.
  • Sun, Dec 28 2014 8:59 PM In reply to
    • mtahir
    • UK
    • Posts 480
    • Points 5,865
    Re: BCC8 and MC8.3
    If I have a MC5.5 project which uses BCC effects, what happens to my project when I import it into MC8.3?
    MC2018.1 (Win7) | Dell T7500 with 2 x 6-Core Intel Xeon X5690 3.46GHz CPUs | Triple-Channel 64GB (32GB per CPU) 1333MHz DDR3 EEC FBDIMM | 3GB nVidia Quadro... [view my complete system specs]
    Filed under: , ,
  • Sun, Dec 28 2014 11:11 PM In reply to
    • jwrl
    • Melbourne, Australia
    • Posts 8,384
    • Points 97,000
    Re: BCC8 and MC8.3
    Unless you have a 64-bit version of BCC you lose the effects.  They become unknown effects.  That may not matter if they've already been rendered and you don't need to change them.  As soon as you do anything to unrender them it will become a serious problem.
  • Mon, Dec 29 2014 8:18 AM In reply to
    • snedker
    • Joined on Tue, Apr 29 2008
    • Denmark , Odense
    • Posts 49
    • Points 630
    Re: BCC8 and MC8.3
    Hi
    I´ve got this email from Boris
    Hello Jan Erik,
    We released BCC AVX 9 to support Avid MC 8.
    BCC AVX 8 does not support Avid MC 8.
    Best regards,
    David d'Arville
    Director of Sales
    Boris FX
    Best regards
    Jan/snedker
    Intel 980X,12 GB RAM ,Asus Sabertooth X58 ,PNY FX3800 graphic , 240GB SSD vertex2, M-Audio Profire 610 .Win7 64 bit UK , Avid MC 8.4.0-Dongle [view my complete system specs]
  • Mon, Dec 29 2014 12:35 PM In reply to
    • BarkinMadd
    • Ontario, Canada
    • Posts 4,621
    • Points 60,375
    Re: BCC8 and MC8.3
    OK folks - can we have Avid chime-in on this one?
    We were told explicitly that an upgrade to BCC 9 would not be required and, in fact, I tested BCC 8.2 with MC 8.2 and they seemed to be compatible. I have since updated to BCC 9 for other reasons so I cannot test BCC 8.2 with MC 8.3.
    I am surprised that Boris is essentially telling MC users that they have to spend an additional $599 when they upgrade their $299/yr for MC 8.
    Cost of ownership is really rising - and again, no consideration for the hobbiest and one-man show. What I mean is that if you think of Avid as only for big budget shows then we can all agree that an extra couple of hundred dollars here and there is not huge (particularly if it saves time) but for the hobbiest and one man show, this is quite a bit of cash. So - is Avid going after a broad range of users or are they returning to the days of old where they focus on Hollywood editors?
    FYI - Boris didn't release BCC 9 to support MC 8 (that mis-represents the truth, IMO). What they may be saying is that they aren't qualifying BCC 8 with MC 8 (i.e., they are not testing the two together and will not patch BCC 8 if an incompatibility is found). This I can understand - it would be up to Avid, in this case, to ensure that they don't change MC in such a way as to make BCC 8 incompatible...
    Avid?
    Camera(s) PXW-X70, HDR-FX1, Hero 6 Black | MC 18.12.1 | QT 7.7.9 | Continuum 2019 | Sapphire 2019 | Mocha Pro 2019 | Titler Pro 6 | Windows 10 Pro x64... [view my complete system specs]
    Steve
    ______________________
    www.nelliedogstudios.com
  • Mon, Dec 29 2014 1:06 PM In reply to
    • sasfog
    • Posts 314
    • Points 3,935
    Re: BCC8 and MC8.3
    The mystery thickens and also may explain why BCC 8 seems to have vanished from my system.
    i have tried downloading bcc8.2 from my avid download centre account - all that gets downloaded from the link is a folder with the release notes inside, when I have tried running the installer it takes me to a registration pop up and then installation fails.
    i have taken this up with boris and am waiting to hear back from them.
    looks to me like something is not as it should be.
    graham
  • Mon, Dec 29 2014 3:48 PM In reply to
    • BarkinMadd
    • Ontario, Canada
    • Posts 4,621
    • Points 60,375
    Re: BCC8 and MC8.3
    Download BCC 8.2 from BorisFx.com
    Steve
  • Mon, Dec 29 2014 5:10 PM In reply to
    Re: BCC8 and MC8.3
    BarkinMadd:
    I'm running BCC8.2 with MC8.3 and it works fine.  I didn't do any uninstalling, reinstalling, or deactivating of BCC before I upgraded to MC8.3, so if you (or anyone) was on BCC 8.2 prior to upgrading to MC 8.3, you should be fine.
    BarkinMadd:
    This is a user-to-user forum.  Sometimes Avid people participate, but if you want a direct response from them, your best option is to contact Avid Support.
  • Mon, Dec 29 2014 5:48 PM In reply to
    • BarkinMadd
    • Ontario, Canada
    • Posts 4,621
    • Points 60,375
    Re: BCC8 and MC8.3
    Been around here for a very long time, Carl. I don't want anything from Avid but if Boris is misleading Avid's customers in some way, I think it is up to Avid to sort that out with Boris.
    As you say, you have BCC 8.2 working just fine with MC 8.3. Maybe the problem exists if you try to install BCC 8.2 fresh on an MC 8.3 machine (or maybe there is no problem and the OP needs to work a bit harder to get the 8.2 installer from Boris).
    Cheers
    Steve
  • Mon, Dec 29 2014 6:57 PM In reply to
    • mjolnarn
    • Joined on Wed, Feb 8 2006
    • Sweden
    • Posts 13,346
    • Points 159,335
    Re: BCC8 and MC8.3
    I´ve just mailed Boris
    Tomas
  • Mon, Dec 29 2014 7:28 PM In reply to
    Re: BCC8 and MC8.3
    BarkinMadd:
    I know you've been around a while, Steve, which is why I thought it was weird you'd ask for an Avid response, because you know they don't participate regularly here, which means me or one of the other mods would have to first see your post - not a guanrantee when so many people are posting about upgrades - and then send Marianna an email to let her know there's a post she might want to look at.
    If you really want Avid to answer you, it seems to me like it'd be easier to just send Marianna a PM on an email directly.
  • Mon, Dec 29 2014 8:15 PM In reply to
    • fdooman
    • LOS ANGELES
    • Posts 518
    • Points 6,340
    Re: BCC8 and MC8.3
    First of all thank you so much snedker for post this public awareness, I have been Avid user for many years with all the respect to all of the mods contributing their time on this forum. Marianna is out of questions, she is truly a backbone for Avid.
    I believe we have to hear a statement from Mr. Luis Hernandez on this especially few days left to reach the deadline date to upgrde. We as a Avid users requesting Avid to practice to be more of a transparent on this issue, this will avoid users from trashing their investments on future upgrades.
    Symphony 6.0 on PC MC 6 on MAC Pro 3.2 GHZ 2008 model, 8 Gig of ram, Nvidia 8800 GT video card. 500 Gig system drive, 320 gig extra drive, Cineraid 2TB... [view my complete system specs]
