Latest post Thu, Feb 19 2015 10:26 AM by KaH. 9 replies.
Page 1 of 1 (10 items)
  • Mon, Nov 24 2014 2:46 PM
    • KaH
    • Joined on Tue, Oct 2 2012
    • Posts 20
    • Points 220
    AMT 2.10.0.923 fails to open any P2 MXF File
    I've just updated my AMT development version from 2.8 to 2.10. Now OpenMxfFile fails on any P2 MXF OP Atom derived file with error code 72 (AMT_UNKNOWN_EXCEPTION_RAISED). Rewrapped OP1a files still work as expected.
    Console output shows the following error:
    Syntaxerror.
    [ 24-11-2014 14:38:55,103 ] Assertion "Get DisplayWidth succeeded" violated in r
    outine "AA::Media::Media".
    The violation occurred at line 238 in file "..\..\AA\Media.cpp".
    The condition "hr == AAFRESULT_SUCCESS" was false.
    Is this a known issue? How to fix this problem?
    Regards,
    Kai
  • Wed, Dec 3 2014 2:42 PM In reply to
    • robg
    • Tewksbury, MA
    • Posts 494
    • Points 5,605
    • Avid Developer Moderator
      Avid Employee
    Re: AMT 2.10.0.923 fails to open any P2 MXF File
    kai,
    Sorry for the delay. I'll see if I can can an answer for this soon...
    - Rob
  • Wed, Dec 3 2014 3:46 PM In reply to
    • andym
    • Joined on Thu, Jan 13 2011
    • Posts 116
    • Points 1,400
    kai,
    AMT is not designed to operate directly on native P2 files, its purpose is to read and write OP-Atom files in the Avid domain. For reading and writing native P2 files, you will need to harness a commercial MXF toolkit.
    Andy
  • Wed, Dec 3 2014 4:02 PM In reply to
    • KaH
    • Posts 20
    • Points 220
    Andy,
    typically we use bmx (mxf toolkit) to create "clean" OP Atom files that are handed over to AMT. This worked up to AMT2.8. Starting with AMT 2.10 the same files cause internal AMT exceptions.
    Kai
  • Wed, Jan 21 2015 12:39 PM In reply to
    • KaH
    • Posts 20
    • Points 220
    Hi Rob,
    any news about this issue?
    - Kai
  • Mon, Feb 9 2015 5:04 PM In reply to
    • Vadym
    • Joined on Thu, Apr 17 2014
    • Posts 227
    • Points 2,740
      Avid Employee
    Hi Kai,
    You'd need to open Support case for the behavior you see to investigate further. Please find the issue reporting template in the AMT documentation, fill it in and submit with your case.
    Vadym
    PS There is also AMT 2.11 that may fix your issue unintentionally
  • Tue, Feb 10 2015 7:51 AM In reply to
    • KaH
    • Posts 20
    • Points 220
    Hello Vadym,
    ok, I'll open a Support Case after I've tested AMT 2.11.
    One thing really bothers me. When we started our AMT based development in 2013 we got updates regulary without asking for them. About a year ago our contact person at avid stopped sending notifitcations. Since then we had to ask several times before we get any answer (if at all) from this person. Typically I have to send about 4-5 emails until I get a reply. Even our customers often know more about available updates than we do. This is really the worst developer experience since I work with Avid SDKs (started around 2006).
    Regards,
    Kai
  • Tue, Feb 10 2015 1:58 PM In reply to
    • robg
    • Tewksbury, MA
    • Posts 494
    • Points 5,605
      Avid Employee
    Kai,
    I am sorry to hear about your experience with our AMT SDK support. I will look into the reason why you stopped getting updates for AMT and had poor response to your emails.
    Sincerely,
    - Rob
  • Wed, Feb 11 2015 1:36 PM In reply to
    • KaH
    • Posts 20
    • Points 220
    Thank you Rob for caring about our problem and solving it quickly.
    - Kai
  • Thu, Feb 19 2015 10:26 AM In reply to
    • KaH
    • Posts 20
    • Points 220
    Since version 2.11 still shows the same problems handling P2 derived files I've opened a support case.
    - Kai
