Latest post Mon, May 12 2008 7:24 PM by Baklap. 8 replies.
Page 1 of 1 (9 items)
  • Fri, Mar 24 2006 10:57 PM
    • patno
    • S/W France
    • Posts 24
    • Points 280
    Install Xpress Pro problems any advice on the correct way to install from original CDrom?
    I have an Xpress Pro system (4.0.1) on an HP 8000 workstation. Suddenly it did not want to recognise the dongle (dongle has been in for two years..never been moved and USB ports are fine). So I removed the Avid and have reinstalled it several times to no avail. I get the feeling that the tree of installation is incorrect..just does not look the same at all. Have updated the dongle driver and repaired/reinstalled software but it just starts and then quits after a few seconds. I'm running on XP Professional with a Mojo and all is original (legit) Avid stock. I am getting quite frustrated by all this, does any one have any advice in the correct installation procedure. The CDROM seems to tell me everything is OK but it still won't work. And by the way it tells me that I am not registered which I am. Suggestions please as I have a job in hand! I shold add that I have Boris FX and some others installed..should I remove everything connected with Avid? Many thanks in advance.
    WIN XP PRO sp2, HP XW/8000, Avid Xpress Pro 4.01 with Mojo. 80gb hard drive. Intel Xeon cpu 2.80ghz, 1.0gb RAM, Nvidia Quatro4 980 XGL. System only used... [view my complete system specs]
  • Sat, Mar 25 2006 2:45 AM In reply to
    • camoscato
    • Posts 4,109
    • Points 49,270
    • Moderator: Avid Free DV
      Moderator: Avid Xpress Pro PC
      Moderator: Meridien
    Re: Install Xpress Pro problems any advice on the correct way to install from original CDrom?
    Here's a post from Avid Customer Service on how to handle dongle problems during upgrades or installation:
    http://www.avid.com/exchange/forums/72/ShowPost.aspx
    good luck,
    Carl
  • Tue, Mar 28 2006 12:38 AM In reply to
    • patno
    • S/W France
    • Posts 24
    • Points 280
    Many thanks Carl,
    I did go through all that before I posted my original query....my problem, after several removals/repairs/re-installs, is that when I go into Avid I get the splash screen for a few seconds and then it dies on me. No messages, no notification just closes. It tells me me that the sytem is there (in add/remove) but just will not open. I have no problem with the dongle now, that is recognised..........the "not registered system" bit is not a problem at the moment, can sort that out later after reading what you pointed me to.....my frustration is that, I think, I have re-installed it all correctly but it still will not open. Any suggestions?..Maybe something lurking in there somewhere? Certainly no viruses or spyware.
    I should add that we have had one or two problems here (in rural France) with electricity problems but, as I said before the system has been up and running perfectly for the last couple of years. No dongle removals, the rest of my system is working fine...everything except the Avid...........AAAAArgh.!
    I should say that I disable AV and Firewall before re-install.
    I wish I could say that "don't Panic" but I am!
    Barry.
  • Tue, Mar 28 2006 12:53 AM In reply to
    • Adman
    • Atlanta Georgia, USA
    • Posts 3,723
    • Points 41,340
      Moderator: Avid Xpress DV PC
      Moderator: Avid Xpress Studio
    I strongly suggest that you update your detailed system specifications in your user profile by clicking on your user name at the top of the screen. You may need to register as well before doing this.
    This will make it much easier for everyone to help troubleshoot your problem.
    Dell Precision 650, 3.06 Ghz, 2 SCSI drives, 600 GB LaCie D2, 1.5 Mb Ram, Nvidia FX500 Suite 1. Avid Media Composer v2.7, Avid Studio Toolkit v 5.7... [view my complete system specs]
  • Tue, Mar 28 2006 1:06 AM In reply to
    • patno
    • S/W France
    • Posts 24
    • Points 280
    Thanks Robert,
    I just did but it did not seem to want to know! I'll try again.
    FYI. I am running WIN XP Pro with Avid Xpress pro/Mojo on an HP XW8000 workstation all original as supplied.
    Barry
  • Sun, May 11 2008 9:01 AM In reply to
     hey Barry -
    i'm curious what your solution was to this problem...?  Seems like i'm having the identical problem with Xpress Pro v.5.8...
    thanks
  • Sun, May 11 2008 5:22 PM In reply to
    • Baklap
    • Hilversum - The Netherlands
    • Posts 6,498
    • Points 76,950
    The first thing i would do is get a hold of 4.6 because all before that is SP1 and not SP2. 4.6 is by far the most stable release from the 4.x series.
    Un-install all avid related, backup projects and settings (ask if you don't know how) and then get rid of all Avid related stuff in the program files. Uninstall the sentinel drivers as well. Make sure you unplug the dongle and reboot. Then install 4.6 and reboot.. then after boot insert the dongle again. move back projects and settings and hopefully continue to edit.
    Menno
    Test-Intel Core2Duo 6800,GTS8800 Nvidia (soft modded into Quadro FX4600),Soundblaster Live 5.1, 21" Samsung display [view my complete system specs]
    Dutch AV forum
  • Mon, May 12 2008 7:10 PM In reply to
     thanks menno -
    actually it was my nvidia graphics card driver; downloaded the current version and it solved the launching problem.  i have the forum here to thank since that's where i learned about the fix
  • Mon, May 12 2008 7:24 PM In reply to
    • Baklap
    • Posts 6,498
    • Points 76,950
    Good.. thx for the feedback!
    Menno
    Dutch AV forum
