Latest post Tue, Apr 14 2015 8:48 AM by rwassall. 19 replies.
Page 2 of 2 (20 items) < Previous 1 2
  • Tue, Apr 7 2015 1:04 PM In reply to
    • robg
    • Tewksbury, MA
    • Posts 494
    • Points 5,605
    • Avid Developer Moderator
      Avid Employee
    Re: Powershell media export
    Richard,
    Please send the XML Request from SoapUI that is causing the SAAJ object model error. We'll take a look at it here...
    - Rob
  • Tue, Apr 7 2015 1:13 PM In reply to
    • rwassall
    • Joined on Fri, Nov 14 2014
    • Posts 11
    • Points 135
    Hi Rob,
    It's exactly the same as the original call, but just with a MobID added e.g.
    call made to
    http://10.162.22.10/services/Jobs
    <soapenv:Envelope xmlns:soapenv="http://schemas.xmlsoap.org/soap/envelope/" xmlns:typ="http://avid.com/interplay/ws/assets/types" xmlns:typ1="http://avid.com/interplay/ws/jobs/types">
       <soapenv:Header>
          <typ:UserCredentials>
               <typ:Username>imagen</typ:Username>
               <typ:Password>xxxxx</typ:Password>
          </typ:UserCredentials>
       </soapenv:Header>
       <soapenv:Body>
          <typ1:SubmitJobUsingParameters>
             <typ1:Service>com.avid.dms.longgopexport</typ1:Service>
             <typ1:InterplayURI>interplay://DUBWG?mobid=060a2b340101010101010f0013-000000-54b4f1ffca9e001c-060e2b347f7f-2a80</typ1:InterplayURI>
             <typ1:Parameters>
                <jobs:Parameter Name="MobID">060a2b340101010101010f0013-000000-54b4f1ffca9e001c-060e2b347f7f-2a80</jobs:Parameter>
               <typ1:Parameter Name="High Priority">false</typ1:Parameter>
               <typ1:Parameter Name="TM_Server">dub-ip-tm1</typ1:Parameter>
               <typ1:Parameter Name="TM Profile">DAM</typ1:Parameter>
               <typ1:Parameter Name="Priority">50</typ1:Parameter>
             </typ1:Parameters>
          </typ1:SubmitJobUsingParameters>
       </soapenv:Body>
    </soapenv:Envelope>
  • Tue, Apr 7 2015 8:59 PM In reply to
    • robg
    • Tewksbury, MA
    • Posts 494
    • Points 5,605
      Avid Employee
    rwassal,
    The issue that's causing the "Problems creating SAAJ object model" error is a mismatch in the namespace prefix for the MobID parameter.
    Try replacing "jobs" with "typ1" here:
    <typ1:Parameter Name="MobID">060a2b340101010101010f0013-000000-54b4f1ffca9e001c-060e2b347f7f-2a80</typ1:Parameter>
    XML is a bit funky in that you can use any namespace you want for a prefix (like typ, typ1, jobs, assets, etc.), as long as it is defined at the top and is consistent within the block (but this leads to copy and paste errors...).
    - Rob
  • Wed, Apr 8 2015 12:42 PM In reply to
    • rwassall
    • Posts 11
    • Points 135
    Apologies Rob, I should have spotted that one.
    After changing the namespace alias the call worked, I received a JobURI, but when I use GetJobStatus to check the progress, I receive the following error and no file is output
    [Error] Incompatible Transfer Manager API version, error: The server is not responding.
  • Tue, Apr 14 2015 8:48 AM In reply to
    • rwassall
    • Posts 11
    • Points 135
    Some further info.
    The client has reconfigured the profile. I submit a job, query the JobURI for progress, I see one percent complete, query the progress again, get the "Incompatible Tranfer Manager API version" error and no file is output to the remote FTP location.
    Any ideas?
    Richard
