Latest post Wed, Nov 12 2014 12:00 AM by Isaac T.. 5 replies.
Page 1 of 1 (6 items)
  • Mon, Oct 20 2014 8:28 AM
    • pablo12sg
    • Joined on Sat, Aug 7 2010
    • Posts 13
    • Points 175
    NEMFileWriter has detected upstream pipe stall
    Hi:
    I wanted to make a query. See if someone also has this problem.
    I have installed the AMC 7.0.4 on OS X 10.9.4.
    I have material from a Sony Handycam HDR-CX740. Material recorded at 1080 50p (AVCHD).
    When I try to import or consolidate, Avid will not let me. But let me make trascode. And here comes the problem. Halfway through the process, I get an error and not let me do transcode correctly.
    Exception: NEMFileWriter::ExecuteInternal TIMEOUT -  NEMFileWriter has detected upstream pipe stall...
    I've also tried 8.1.0 AMC but the error persists.
    Any idea ?. Thanks in advance. A greeting.
  • Mon, Oct 20 2014 9:05 AM In reply to
    • pablo12sg
    • Posts 13
    • Points 175
    Re: NEMFileWriter has detected upstream pipe stall
    Just try with AMC 6.5.4.2 and no problem.
    But I would be interested to work in version 7 at least.
    Could it be a bug in version 7 and 8?
    A greeting .
  • Mon, Oct 20 2014 9:57 AM In reply to
    • carlgmi
    • Western Australia
    • Posts 754
    • Points 9,340
    +1 on PC 8.1 with AVCHD import.  Problem clip then imports correctly on second attempt.  For us this is ex NAS storage and I put it down to a network slowdown at the times it occurred.
    MC8.10 Win 7 64 with Dongle, Dual 10 core Xeon, Quadro K4000, Adaptec RAID 5-8x3TB, External TB2 4x3TB, 64G RAM, BM Intensity Pro 4K. NewBlue Titler 6... [view my complete system specs]
    Vote 1 - Dongles.
    UME an old engine, now with 4K, mags and furry dice....
  • Mon, Oct 20 2014 4:34 PM In reply to
    • Isaac T.
    • Joined on Mon, Jan 9 2006
    • New York / Knoxville, TN
    • Posts 747
    • Points 8,810
    Usually it means one, or a combination, of these:
    1. You have a spanned clip.
    2. The source or destination drive can't keep up with the transcode.
    Options:
    1. Check your drive speed with Blackmagic Disk Speed Test. (Free)
    2. If your local drives are fast enough, and your transcoding from a network drive, copy the files to a local drive, then retry the transcode.
    3. Join the spanned clips into one, then retry the transcode. Sony might make a support app for your camera.
    Unfortunately, this error is a long-standing one with AVCHD. If none of these work, search the community. Google's site search feature is a big help. Here was my search string:
    NEMFileWriter has detected upstream site:community.avid.com
    Mid-2010 Mac Pro • 2018 MacBook Pro [view my complete system specs]
    isaact.co | Twitter | Instagram | Vimeo
    Writer: The Frame.io WORKFLOW Guide - http://workflow.frame.io/
    Post Workflow Consultant - https://isaact.co/
  • Sat, Nov 8 2014 10:19 AM In reply to
    • pablo12sg
    • Posts 13
    • Points 175
    First, thanks for the help.
    My clips are not spanned. And I make transcoding from an internal hard drive (1TB 7200rpm) to an internal SSD.
    I'm googling to see if I find something else.
    Thank you.
  • Wed, Nov 12 2014 12:00 AM In reply to
    • Isaac T.
    • Posts 747
    • Points 8,810
    pablo12sg:
    I'll be more explicit – I Google'd it for you:
    https://www.google.com/?gws_rd=ssl#q=NEMFileWriter+has+detected+upstream+site%3Acommunity.avid.com
    Something crazy to try - slow your down your computer while transcoding:
    http://community.avid.com/forums/p/122935/741677.aspx#741677
    If that works, then it's slow disk I/O.
