Latest post Thu, Apr 13 2017 8:00 PM by Richard@TMD. 2 replies.
  • Tue, Oct 7 2014 3:53 PM
    AvidTMAuto 3.0/3.1 Internal Error
    Our customer has updated to Interplay Transfer Client 3.1.  While I can downgrade the Tranfers Client to use AvidTMAuto 2.7 x64 I cannot get Avid Transfer Client 3.0 (with AvidTMAuto 3.0) or Avid Tranfer Client 3.1 (AvidTMAuto 3.1) to function.
    Could you tell me what "error 6" means?  I know this file is good that is going into Avid, since I was able to transfer this file with Avid Tranfer Client 2.5 (with AvidTMAuto 2.7).
    [984] Entering _AutomationAPI::GetFromIngest()
    [984] SetupFileName: AvGenericFtp_Setup
    [984] _AutomationAPI::GetFromIngest() - Setup loading dll: AvGenericFtp_Setup
    [984] _AutomationAPI::GetFromIngest() - MediaType is configured for AAF
    [984] _AutomationAPI::GetFromIngest() - Setup DLL AvGenericFtp_Setup failed to create proxy mob, error: 6
    [984] _AutomationAPI::GetFromIngest() - Calling DeleteBuffer on the buffer
    [984] _AutomationAPI::GetFromIngest() - Calling the Delete method on the SetupObject
  • Thu, Apr 13 2017 6:46 PM In reply to
    Re: AvidTMAuto 3.0/3.1 Internal Error
    Could the Failed to create proxy mob, error 6 be explained?  This has come up again with Tranfer Client 3.7.1.1 and AvidTMAutoAPI.dll v3.7.1.55335.
  • Thu, Apr 13 2017 8:00 PM In reply to
    Hi - I expect that there is something with reading the Generic FTP settings.  They are set, since all I ahve to do is uninstalled 7.1.1 and reinstall 3.1.1 and all is well.
    Richard@TMD:
    v7.1.1 does not work
    [6020] Entering AvidTMA::_Host::_Host()
    [6020] Entering AvidTMA::_Host::Initialize(AutomationAPI**)
    [6020] Loading DLL -  xfermgrapi
    [6020] API Object addr: 0x002d3d30
    [6020] Calling GetAPIVersion()
    [6020] Calling IsAPIVersionCompatibleWithServer(0.8)
    [6020] CWinAdminCredential: Impersonation not needed
    [6020] APIVersCompat: API is compatible with the server
    [6020] Entering _AutomationAPI::GetFromIngest()
    [6020] SetupFileName: ?????????
    [6020] _AutomationAPI::GetFromIngest() - Setup loading dll: AvGenericFtp_Setup
    [6020] _AutomationAPI::GetFromIngest() - MediaType is configured for AAF
    [6020] _AutomationAPI::GetFromIngest() - Setup DLL AvGenericFtp_Setup failed to create proxy mob, error: 6
    [6020] _AutomationAPI::GetFromIngest() - Setup DLL LastError:
    [6020] _AutomationAPI::GetFromIngest() - Calling DeleteBuffer on the buffer
    [6020] _AutomationAPI::GetFromIngest() - Calling the Delete method on the SetupObject
    v3.1.1 works:
    [5592] Entering _AutomationAPI::GetFromIngest()
    [5592] SetupFileName: AvGenericFtp_Setup
    [5592] _AutomationAPI::GetFromIngest() - Setup loading dll: AvGenericFtp_Setup
    [5592] _AutomationAPI::GetFromIngest() - MediaType is configured for AAF
    [5592] Generic FTP Setup DLL FtpProfileName:tmd_test
    [5592] Generic FTP Setup DLL: FTP PARAMETERS From XML Host:dssp-isi-t, User:****, Password:****, Port:21
    [5592] Generic FTP Setup DLL: FTP PARAMETERS Host:dssp-isi-t, User:*****, Password:*****, Port:21
    [5592] _AutomationAPI::GetFromIngest() - Setup DLL created a proxy mob
    [5592] _AutomationAPI::GetFromIngest() - Calling GetFromIngest() user: TMD, hostname: tmd_test, workspace: TUR, bufferLength: 149813
    [5592] _AutomationAPI::GetFromIngest() - successful
    [5592] _AutomationAPI::GetFromIngest() - Calling DeleteBuffer on the buffer
    [5592] _AutomationAPI::GetFromIngest() - Calling the Delete method on the SetupObject
