Latest post Mon, Mar 30 2015 3:33 PM by usatraveler. 3 replies.
  • Mon, Sep 29 2014 8:46 AM
    Fastest way to export HD for viewing puposes
    I am wondering what your experiences are for the fastest workflow in exporting HD sequences for viewing. Normally i use MXF export and transcode it with Adobe Media Encoder but that isn't failsafe because i get all kind of red flashes when frames are "corrupt" (which they are obviously not). This method takes a little less then 1:1 in overal time.
    Te method i am turning to now is export to quicktime with the H264 codec straight away from avid. But it takes ages. About 2:1 in sequence length.
    Generally i'am working with XDCAM HD 50Mbit footage. Which cannot be exported using Same as Source settings. I run a fairly fast Z420 system. When exporting from avid i use nowhere near te maximum capacity of my CPU and Memory.
    For this workflow i prefer speed over quality
    Would like to know your workflows.
    HP Z440 | Win 7 | MC 8.5 | AJA KONA Lhi HP Z420 | Win 8 | MC 7.0.4 | AJA IO Express HP Z420 | Win 8 | MC 8.2 | Matrox MXO2 mini HP Z400 | Win 8 | MC... [view my complete system specs]
    Filed under: , ,
  • Mon, Sep 29 2014 10:01 AM In reply to
    • Joachim Claus
    • Seeheim-Jugenheim, Germany
    • Posts 945
    • Points 12,070
    Re: Fastest way to export HD for viewing puposes
    The answer depends on what you use for "viewing". If it is your computer screen, then the fastest export is QuickTime Reference. You can play QT.Reference files with QuickTime player or many other players.
    If it is not your computer screen, e.g. a TV set or an iPad, then I would use the above mentioned QT-Reference file and feed it into Squeeze, and select an appropriate destination format.
    Joachim
    Joachim Claus
  • Mon, Mar 30 2015 1:57 PM In reply to
    • buchel
    • Joined on Wed, Mar 15 2006
    • Cologne, germany
    • Posts 64
    • Points 750
    Late answer:
    XDCAM HD is a Long Gop Codec so you are not able to export sameassource or QT Ref.
    Since Quality does not matter we are going with DV25 and then further compression (mp4) with Soerenson Squeeze.
    40 workstations HP and DIY, WIN 10 64bit MC 2018.12.3 Elements Shared Storage 720TB Arista 40GbE Backbone, 10 GBaseT Clients. Editshare shared storage... [view my complete system specs]
  • Mon, Mar 30 2015 3:33 PM In reply to
    Overall, the end goal is to be able to export a QuickTime Reference of your sequence.  HOW you get there depends on a number of factors.
    If you're working a lot with XDCam, you MIGHT consider buying the Calibrated{Q} XD Decode product.  It enables QT-Referencing this codec.
    http://www.calibratedsoftware.com/Products/XDDecodeV2/QXD.php
    On the Mac, the similar solution is to install a Final Cut Pro Studio product - like the $299 Final Cut Pro X, OR the $49 Compressor or Motion.  All of those will install the Pro Apps codecs, including XDCam - which then allows me to export QT References of sequences that use XDCam media.  The Calibrated product would enable a similar workflow on Windows.
    So, on the Mac, my workflow is generally to consolidate the raw stuff (or just consolidate my SEQUENCE selecting the "AMA media only" option), and then QT-Ref it for exports.  And then, create outputs from Sorenson Squeeze (or your chosen favorite encoder) - which is MUCH better at creating the H264 files than MC is.
    Otherwise, if you don't buy Calibrated, you can either mixdown your sequence to DNxHD and QT-Ref that sequence, OR transcode your sequence and export a QT-Ref of that.  The mixdown gives you something you can delete as soon as you finish creating your file in Squeeze.  A sequence transcode gives you material you can fairly easily make further edits on, and then QT-Ref a new edited sequence again.
    Number of different ways to go.
