Latest post Wed, Jun 17 2015 7:32 PM by xudon. 4 replies.
  • Thu, Sep 25 2014 8:37 PM
    • xudon
    • Joined on Tue, Apr 15 2014
    • Posts 14
    • Points 180
    Set attributes with web services
    I have a couple of questions with set attributes for assets.
    First, what is the syntax to set attributes in dotnet. What I put in list below gave me error in run time.
    Dim port As New AssetsPortTypeClient()
            Dim creds As New InterplayAssetsWS.UserCredentialsType()
            creds.Username = ""
            creds.Password = "l"
            Dim param As New SetAttributesType()
            param.InterplayURIs(0) = "mobid..."
            param.Attributes(0).Group = "SYSTEM"
            param.Attributes(0).Name = "END"
            param.Attributes(0).Value = "04:01:59:14"
            Try
                Dim response As SetAttributesResponseType = port.SetAttributes(creds, param)
                If Not IsNothing(Response.Errors) Then
                    lblInfo.Text = Response.Errors.ToString
                Else
                    lblInfo.Text = ""
                End If
            Catch ex As Exception
                lblInfo.Text = ex.Message.ToString
            End Try
    Second, I know that I should not set SYSTEM attributes, but this asset is subclip I created in my program and wanted to fix the system.end timecode.  Can I do it?
    As always thanks a lot for looking into this.
    Don
    Filed under: ,
  • Thu, Sep 25 2014 9:38 PM In reply to
    • robg
    • Tewksbury, MA
    • Posts 494
    • Points 5,605
    • Avid Developer Moderator
      Avid Employee
    Re: Set attributes with web services
    Don,
    The runtime error can be fixed by allocating the param.InterplayURIs and paramAttribute arrays (see the source code below).
    But you will find that this will yeild a "The SYSTEM attribute group is read-only" error.
    Although you cannot change the end timecode of an asset, you can create a new subclip with CreateSubclip() call.
    Hope this helps,
    - Rob
    Imports VSBasicTest2.InterplayAssetsWS
    Public Class Form1
        Private Sub Button1_Click(sender As Object, e As EventArgs) Handles Button1.Click
            creds.Username = "a"
            creds.Password = "a"
            param.InterplayURIs = New String(0) {}
            param.InterplayURIs(0) = "interplay://WGC?mobid=060a2b340101010101010f0013-000000-000a11d8fc07fbf2-060e2b347f7f-2a80"
            param.Attributes = New AttributeType(0) {}
            param.Attributes(0) = New AttributeType()
            param.Attributes(0).Value = "01:01:01:06"
            Try
                If Not IsNothing(response.Errors) Then
                    lblInfo.Text = response.Errors(0).Details.ToString()
                Else
                    lblInfo.Text = ""
                End If
            End Try
        End Sub
    End Class
  • Fri, Sep 26 2014 9:28 AM In reply to
    • andym
    • Joined on Thu, Jan 13 2011
    • Posts 109
    • Points 1,285
    Hi xudon,
    I cannot comment on the first question but no, you cannot set system attributes unless you change the underlying object, in this case the sub clip. That is the nature of a system attribute.
  • Fri, Sep 26 2014 2:15 PM In reply to
    • xudon
    • Posts 14
    • Points 180
    Thank you very much to both for the fast response. Rob's answer pointed me to the right direction.
  • Wed, Jun 17 2015 7:32 PM In reply to
    • xudon
    • Posts 14
    • Points 180
