Latest post Fri, Aug 22 2014 1:09 PM by Terry Snyder. 4 replies.
  • Thu, Aug 21 2014 5:25 PM
    Final Cut Envy... Exporting Alpha Channel
    An FCP editor sent me animated lower thirds as a .mov file with alpha channel.  He said it was easy to export.   There are many times I would like to export just an alpha channel track from MC.  Whenever I do this, the export does not retain the alpha channel.
    Is there a way to do this directly from MC?
    MC 2018.4 with Symphony, Matrox MX02 Mini Max, Win 7 Pro, HP Z800 2x6-Core 3.2Ghz Xeon, 48GB ram, Quadro K4200, SanDisk Extreme 240GB SSD as system drive... [view my complete system specs]
  • Thu, Aug 21 2014 9:05 PM In reply to
    • Butcher
    • Joined on Mon, Apr 17 2006
    • Jacksonville, FL
    • Posts 1,442
    • Points 18,630
    Re: Final Cut Envy... Exporting Alpha Channel
    Avid doesn't support alpha channels on export.  You could export the graphic fill and the black and white matte as two separate files, and whoever you give them to could recomposite them on their end.
  • Thu, Aug 21 2014 9:56 PM In reply to
    • Atomike
    • Nebraska
    • Posts 730
    • Points 11,135
    Or import them into After Effects (if you have that) and export out as a Quicktime w/ alpha enabled.
    Media Composer version: usually newest release, or 1 behind. Nvidia GTX 1070Ti Windows 10, Core i7 8700K processor, ASRock GA 1151 Z370 Motherboard... [view my complete system specs]
    I spend most of my time between New York and Los Angeles.  In Nebraska.
  • Fri, Aug 22 2014 1:07 PM In reply to
    Butcher:
    I hope a future release will add this ability.   If other NLE's can do it, Avid needs to stay competitive.   It's a useful and much needed feature.
  • Fri, Aug 22 2014 1:09 PM In reply to
    Atomike:
    I don't have AE.   Can I do the same thing with AvidFX?
