Latest post Thu, Aug 14 2014 6:23 PM by BobRusso. 1 replies.
Page 1 of 1 (2 items)
  • Thu, Aug 14 2014 9:25 AM
    Log Agregator Bug?
    Hi All
    We have ISIS 7000 with 3 Engines.
    Once it was necessary to collect the logs using the Avid ISIS toolbox.Then, changed my mind
    , I stopped Log Agregator and exit. Now ,after several days, some ISB are still in "Test mode"
    status in Managment Console and "Diagnostic Mode" in Storage Manager.
    How I can correctly "reset" this status?
  • Thu, Aug 14 2014 6:23 PM In reply to
    • BobRusso
    • New Jersey
    • Posts 2,235
    • Points 27,620
      Moderator: Avid ISIS
      Moderator: Avid NEXIS PRO
    Re: Log Agregator Bug?
    I'm not completely sure how you got into this state, could you have started a Disk Test from the Toolbox?
    I'm guessing that you likely have a number of ISBs in this state. The easiest way to clear this is to reboot the chassis from the Switch Agent page. Clearly no one can be working while doing this.
    You could also reboot each ISB in this state one at a time. If someone is capturing while it's rebooting it could cause a underrun and you could be go into network degraded...
    It would be ideal if you could call into support and have them walk you through this.
