Latest post Mon, Jul 10 2017 3:44 PM by RickP. 13 replies.
Page 1 of 1 (14 items)
  • Fri, Aug 8 2014 5:33 PM
    • RickP
    • Cleveland, OH
    • Posts 42
    • Points 450
    Avid DVD 6.1.1 and MC7.0.4 not working, mostly
    I upgraded four (identical) Media Composer 5.5.3 installations with MC 7.0.4.  I did not do anything with the Avid DVD 6.1.1.  After the ugrade, Avid DVD would not start -- the splash screen comes up for a long time, like usual, then it just disappears.  I uninstalled and reinstalled. Now, one works, but the other three do not. They fail in the same way they did after the upgrade.
    Suggestions?  I have repaired, uninstalled and reinstalled, but nothing has helped.
    Media Composer v2018.1 on (17) 27" Core i7 Quad-core iMacs with 16GB RAM and (8) HP Compaq Elite 8200 Core i5-2500 with 16GB RAM and nVidia Quadro... [view my complete system specs]
  • Fri, Aug 8 2014 6:30 PM In reply to
    • gswilson
    • Joined on Thu, Feb 4 2010
    • Belfast, Ireland - now, Frankfurt am Main, Germany
    • Posts 283
    • Points 3,720
    Re: Avid DVD 6.1.1 and MC7.0.4 not working, mostly
    With any luck someone from Avid may check in here. I have MC 6.5, and this version came with Avid DVD 6.4.4 - however in the Download Center the only version available is 6.1.1.
    Avid DVD has been a "dead" product for quite some time, and isn't being offered by Avid anymore. It's very strange though that the last version available can not be downloaded.
    Gerry
    MC 8.9.2, Win 10 Pro CE, Asus X99-E WS, CPU i7-5930K -3,5 GHz, 32 GB DDR4 2666-16 RAM, Nvidia GTX 980 GPU(Driver 384.94),Samsung 850 Pro 512 GB SSD, 6... [view my complete system specs]
  • Sat, Aug 9 2014 1:04 PM In reply to
    • TVJohn
    • Bayonne NJ
    • Posts 4,277
    • Points 52,925
    This is a long shot, try to open any saved projects you have in the documents folder without opening DVDit first...
    Using MC 8.10. Avid FX6.4, Vegas Pro 15/ DVD Architect 6pro, DVDit6.4proHD, CCE Basic, TmpGe Express4, TmpGe Authoring Works 4, DVDLab-Studio. Sony EX-1R, Canon XH-A1, GL2, GL1, Canon EOS 60D
  • Sat, Aug 9 2014 4:27 PM In reply to
    Another guess:   MC 5.5.3 was a 32-bit program and MC 7.0.4 is 64-bit.   When I first upgraded to MC 6, I installed the version of AvidDVD (6.4.4) that came with the 64-bit software.  I would definitely try re-installing the latest version of AvidDVD, if you can find a way to download it.
    MC 8.6.1 with Symphony, Matrox MX02 Mini Max, Win 7 Pro, HP Z800 2x6-Core 3.2Ghz Xeon, 48GB ram, Quadro K4200, SanDisk Extreme 240GB SSD as system drive... [view my complete system specs]
  • Mon, Aug 11 2014 1:08 PM In reply to
    • RickP
    • Cleveland, OH
    • Posts 42
    • Points 450
    Tried that, but no luck.  Still get 45 seconds of splash screen, then nothing.
    TVJohn:
  • Mon, Aug 11 2014 1:14 PM In reply to
    • RickP
    • Cleveland, OH
    • Posts 42
    • Points 450
    Installing Avid DVD 6.4.4 with a "borrowed" license gives me the same result -- 45 seconds of splash screen and then gone.
    Terry Snyder:
  • Mon, Aug 11 2014 1:27 PM In reply to
    • RickP
    • Cleveland, OH
    • Posts 42
    • Points 450
    It just gets curiouser and curiouser.  For grins, I just tried it in Safe Mode.  Avid DVD not only starts up, but it is fully loaded in 10 seconds.
    Time to weed through the auto-starts and drivers.
  • Mon, Aug 11 2014 1:33 PM In reply to
    • Posts 8,906
    • Points 201,610
    RickP:
    Suggestions?
    Rick,
    There is a setting in the Preferences hat says "Auto-load last project on startup"
    You may have had this selected.
    I think it is on by default.
    Unfortunately, if your last project gets corrupted, then Avid DVD will try to load it on start-up.
    Thus resulting in an abortion.
    Safe mode may go round that.
    Check it out in Safe mode again and see if that is selected.
    If so
    Deselect it.
    Then reboot and try again.
    Good luck
    Regards
    Douglas
    AOL IM:  avidmarianna
    Skype: mariannamontague
  • Mon, Aug 11 2014 2:19 PM In reply to
    • RickP
    • Cleveland, OH
    • Posts 42
    • Points 450
    I got hopefull when I saw, not the "Auto-Load last project" but the "Load sample media" box checked on the Safe Mode only system, but not on its normal brother.  Alas, that didn't do it.
    drbgaijin:
    RickP:
    Suggestions?
    Rick,
    If so
    Deselect it.
    Good luck
    Regards
    Douglas
  • Tue, Aug 12 2014 9:15 PM In reply to
    • TVJohn
    • Bayonne NJ
    • Posts 4,277
    • Points 52,925
    Ther are some .tmp folders under Sonic. In the past, deleting some of them has solved some strange problems...
  • Wed, Aug 13 2014 5:05 PM In reply to
    • Sef
    • Maarssen, The Netherlands
    • Posts 1,008
    • Points 13,650
    Changing to TAW5 has solved much more problems for me...
    MC6.0.5, QT version 7.7.3, AvidFX 6.2(64bit), Squeeze Pro 8.5.0.41, AvidDVD 6.4.4 (still in my system, but I don't use it anymore), Boris Continuum... [view my complete system specs]
  • Fri, Aug 22 2014 12:36 PM In reply to
    • RickP
    • Cleveland, OH
    • Posts 42
    • Points 450
    No luck there, either.
    TVJohn:
  • Fri, Aug 22 2014 1:49 PM In reply to
    • DFW Hokie
    • Plano, TX
    • Posts 272
    • Points 3,655
    Sef:
    ^this
    [EDIT:] with the transcodes performed in Squeeze
  • Mon, Jul 10 2017 3:44 PM In reply to
    • RickP
    • Cleveland, OH
    • Posts 42
    • Points 450
    SOLUTION:  Finally determined something must have changed and caused an existing - and once compatible - installation of Roxio Creator Business 10 to cause the problem.  Uninstalled the Roxio and now AvidDVD works just like it used to.
    I only found this as more and more once-working systems stopped working.  This was a common element.
