Latest post Mon, Jun 2 2014 11:55 AM by Félix Sandri. 8 replies.
Page 1 of 1 (9 items)
  • Sat, May 31 2014 8:34 AM
    • Félix Sandri
    • Joined on Fri, May 30 2014
    • Lausanne Switzerland
    • Posts 7
    • Points 75
    MC 8 rental crash when transcode run in backround
    Hello.
    I have 4K AMA link files in my project. Until this point everything work fine.
    I want to transcode them in DNX120. When I clic "run in transcode" an error massage appears "Segmentation fault" in thread "MainThread", at address   0x0 and the software crashed.
    If I try to transcode these files in a normal way - I mean without "run in backround" -, it does work.
    Have someone an idea how to solve this problem?
    One clarification: I am running with Media Composer 8.0 rental. Maybe this could be a reason?...
    Félix.
    MacBook Pro, OSX 10.8.5, processor 2.7 GHz Intel Core i7, 16 Go 1600 MHz DDR3, NVIDIA GeForce GT 650M 1024 Mo [view my complete system specs]
  • Sat, May 31 2014 9:04 AM In reply to
    Re: MC 8 rental crash when transcode run in backround
    Hi Felix,
    Félix Sandri:
    I doubt the license type has anything to do with the error.  Segmentation faults seem to be pretty common.  I'd start with this Knowledge Base article:
    http://tinyurl.com/ou5c5t9
    If that doesn't help, I'd do a Google search for "media composer segmentation fault" and you'll get a lot of results with suggestions.
    Carl
  • Sun, Jun 1 2014 5:16 PM In reply to
    • Félix Sandri
    • Posts 7
    • Points 75
    OK thank you, I'll try to do something.
    F.
  • Mon, Jun 2 2014 9:29 AM In reply to
    • cccu tech
    • Joined on Fri, Jun 17 2011
    • Posts 118
    • Points 1,350
    I haven't tried 8 so this may not be relevant... What type of drive are you trying to transcode to?  Is it a local drive or network drive?  I know background transcoding to network drives doesn't work in 7.
    Avid 5.5.3 Snow Leopard 10.6.8 2007 2x 2.8Ghx Quad Mac Pro 4GB Ram [view my complete system specs]
  • Mon, Jun 2 2014 9:31 AM In reply to
    cccu tech:
    At the moment the only difference between 8.0 and 7.0 is the licensing, so the drive idea is definitely something to check out.
  • Mon, Jun 2 2014 11:20 AM In reply to
    • Félix Sandri
    • Posts 7
    • Points 75
    I am working on an 25To Pegasus2 R8 external disk, connected to my computer via a thunderbolt cable.
    This would be the reason?
  • Mon, Jun 2 2014 11:35 AM In reply to
    • cccu tech
    • Posts 118
    • Points 1,350
    I've not tried this extensively... but I've had no problems background transcoding to a Lacie 5big on thunderbolt.  Have you tried using Dynamic Media Folders to see if the same thing happens?
  • Mon, Jun 2 2014 11:45 AM In reply to
    • Félix Sandri
    • Posts 7
    • Points 75
    No, I didn't try. It's a good idea, I'll see what happens.
    Thank you.
  • Mon, Jun 2 2014 11:55 AM In reply to
    • Félix Sandri
    • Posts 7
    • Points 75
    Does anyone have evere tried to transcode in backround via a thunderbolt cable?
    I'm curious to understand if this could be the reason of the crash.
