Latest post Sat, Jun 14 2014 10:59 AM by pablo12sg. 3 replies.
  • Fri, Mar 7 2014 9:53 AM
    • pablo12sg
    • Joined on Sat, Aug 7 2010
    • Posts 13
    • Points 175
    OS 10.9.1 MediaLog not run
    Good morning:
    I have a problem. I have Media Composer 7.0.3 with OSX 10.9.1. Well, when I boot Avid MediaLog it does not work, apparently having problems with a library: libicudataAvid.dylib
    I tried to upgrade to OSX 10.9.2 but the problem continues.
    This is the report I get:
    _________________________________
    Process:         AvidMediaLog [726]
    Path:            /Applications/Avid MediaLog/AvidMediaLog.app/Contents/MacOS/AvidMediaLog
    Identifier:      com.avid.medialog
    Version:         ???
    Code Type:       X86 (Native)
    Parent Process:  launchd [159]
    Responsible:     AvidMediaLog [726]
    User ID:         501
    Date/Time:       2014-03-07 10:20:04.852 +0100
    OS Version:      Mac OS X 10.9.2 (13C64)
    Report Version:  11
    Anonymous UUID:  C3BEF92E-4E7D-0EE1-1EA0-D40BADAF55E4
    Sleep/Wake UUID: 3CB88A93-AF04-46FF-AD75-2A5441F55332
    Crashed Thread:  0
    Exception Type:  EXC_BREAKPOINT (SIGTRAP)
    Exception Codes: 0x0000000000000002, 0x0000000000000000
    Application Specific Information:
    dyld: launch, loading dependent libraries
    Dyld Error Message:
      Library not loaded: @executable_path/libicudataAvid.dylib
      Referenced from: /Applications/Avid MediaLog/AvidMediaLog.app/Contents/MacOS/AvidMediaLog
      Reason: image not found
    Binary Images:
    0x8fec7000 - 0x8fef9417  dyld (239.4) <2E655535-479B-3E48-ADD3-6278819CA38A> /usr/lib/dyld
    Model: iMac11,1, BootROM IM111.0034.B02, 4 processors, Intel Core i5, 2.66 GHz, 16 GB, SMC 1.54f36
    Graphics: ATI Radeon HD 4850, ATI Radeon HD 4850, PCIe, 512 MB
    Memory Module: BANK 0/DIMM0, 4 GB, DDR3, 1067 MHz, 0x859B, 0x435434473353313036374D2E4D3136464B44
    Memory Module: BANK 1/DIMM0, 4 GB, DDR3, 1067 MHz, 0x859B, 0x435434473353313036374D2E4D3136464B44
    Memory Module: BANK 0/DIMM1, 4 GB, DDR3, 1067 MHz, 0x859B, 0x435434473353313036374D2E4D3136464B44
    Memory Module: BANK 1/DIMM1, 4 GB, DDR3, 1067 MHz, 0x859B, 0x435434473353313036374D2E4D3136464B44
    AirPort: spairport_wireless_card_type_airport_extreme (0x168C, 0x8F), Atheros 9280: 4.0.74.0-P2P
    Bluetooth: Version 4.2.3f10 13477, 3 services, 23 devices, 1 incoming serial ports
    Network Service: Wi-Fi, AirPort, en1
    Serial ATA Device: ST31000528AS, 1 TB
    Serial ATA Device: Crucial_CT240M500SSD1, 240,06 GB
    USB Device: Hub
    USB Device: Ext HDD 1021
    USB Device: Internal Memory Card Reader
    USB Device: BRCM2046 Hub
    USB Device: Bluetooth USB Host Controller
    USB Device: Hub
    USB Device: External
    USB Device: Expansion Desk
    USB Device: Built-in iSight
    USB Device: IR Receiver
    Thunderbolt Bus:
    _____________________________________ Anyone else has this happened...
  • Fri, Mar 7 2014 12:25 PM In reply to
    Re: OS 10.9.1 MediaLog not run
    pablo12sg:
    Looks like your system is on 10.9.2, not 10.9.1.
  • Fri, Mar 7 2014 5:58 PM In reply to
    • pablo12sg
    • Posts 13
    • Points 175
    Was on 10.9.1 and upgraded to 10.9.2 to try, as I explained before.
  • Sat, Jun 14 2014 10:59 AM In reply to
    • pablo12sg
    • Posts 13
    • Points 175
    Any idea? I just upgrade to 10.9.3 with same error.
